C6 OBD-II CANbus PID for Oil Press/Temp?
I have built a data logger for my '06 Z based on an Arduino microcontroller. It uses a CANbus shield to allow me to connect to the car's OBD-II data port and read data from the CANbus (GMLAN). So far, I have been able to read the following data - all PID's are given in hexadecimal:
PID Parameter
0C RPM
0D Speed
11 Throttle Position %
This works fine, but I would like to add oil pressure and oil temperature. This wiki is a good resource for the standard CANbus PID's, and it gives the oil temperature as PID 5C, but I tried that code, and it didn't return any data. I'm suspecting GM put oil temperature under a different code. Also, I cannot find oil pressure at all, and I would really like to have that one.
If anyone has a list of PIDs on the GMLAN for the C6 cars, I'd appreciated any info I can get. Having things like wheel speeds and steering wheel angle would really be great.
PID Parameter
0C RPM
0D Speed
I can't look it up right now, but the gm oil temp and pressure both show on the torque app for android. If you make an account and post this question on their forum you'd probably get a reply from the developer pretty quickly.
I took this screenshot with some of the pids and equations, hopefully this is helpful. I'm not sure if the numbered pids in torque are real or something converted for the app.
Hi, I sold my vette, so I'm not monitoring the forum anymore. When I tested this, I was getting data that seemed to follow oil temperature, but the actual values were incorrect, like your results. I figured there was some additional scaling I needed to consider, but since I sold the car, I just stopped working on this. Sorry I can't be of more help.
