Creaky front suspension
Jun 18, 2013 | 12:12 PM
Hello all,
I did as much research as I could on the forum about front suspension creak and squeak. My 2005 has 121K miles (daily driver) and this past year my front suspension has started to creak when entering a slow speed incline usually when I need to turn. It got worse over time and the research I found said the sway bar bushing needed to be replace.
I replaced the front z51 sway bar bushings with new PFADT polyurethane bushings. for a day or 2 there was zero creak. Yesterday it came back.
Here is a video of what it sounds like. I can make the creak when I jack the car up causing the suspension to drop
OR if I compress the suspension while driving.
http://s66.photobucket.com/user/tiki...99cbc.mp4.html
Jun 18, 2013 | 03:02 PM
No one has any ideas?
Does anyone know what it sounds like when the rubber on the lowering bolts tears or wears off?
Jun 18, 2013 | 03:43 PM
Have the same issue on the rear of my 05'. Let me know what you find please! It's driving me insane.
Jun 18, 2013 | 04:48 PM
have you checked shocks yet? one could be froze up....?
Jun 18, 2013 | 05:45 PM
Quote:
Originally Posted by
C U IN REARVEIW
I willcheck them, but I put new shock on the car at 65K miles. so they only have about 60k miles on them right now.
Jun 18, 2013 | 09:56 PM
Disconnected mine a month ago to see if that was it. Still did it.
Jun 18, 2013 | 09:58 PM
tighten down the newly installed parts.
Jun 18, 2013 | 10:17 PM
S'vette
Glad everyone isn't as helpful as you.
That's the next thing on my list as soon as the LSX is up and running. If I find anything ill post pics and PM you.
Jun 18, 2013 | 10:20 PM
I'm_going_fast_again
You will be surprised that re tightening the links will stop some of the noise. I had the JOC suspension put in and it was creaking like crazy and had everything tightened down and it stopped.
Jun 18, 2013 | 10:23 PM
Your right it does help. Just tightened up my shocks again and the PFADT rear sway bar I put on when I got my car. Went away. Insert foot to mouth.
Jun 18, 2013 | 10:26 PM
glad its fixed. I hate rattles and creaks.
Jun 19, 2013 | 11:20 AM
As soon as I get my wheel back from repair I'll be able to lift the front of the car and retighten things.
Would the end-links ever start to creak like this? Or is is just the sway bar bushings?
Jun 19, 2013 | 06:40 PM
Silicone grease for those bushings will help.
Jun 20, 2013 | 12:16 PM
carpe dm
See I did grease them. the bushings cam with packets of grease so IDK what to do now. Maybe I did not grease them enough?
