DashLogic NPP control, no switches, no wires, OBD-II plug and play
Former Vendor
DashLogic C6 display controller now controls your NPP Exhaust. In addition to getting all the data imaginable displayed on your DIC or HUD, we have added NPP controls by toggling the mirror switch. We don't make you install a switch, you don't wire in anything, you don't modify your Corvette in any way at all. Plug the DashLogic device to the OBD-II port and you are DONE, that is it, take it off and you are 100% stock, no modification to the vehicle in any way. We work in both directions, you can open at any time or you can hold it closed under any condition.
You can check out many other features of the DashLogic display controller here http://forums.corvetteforum.com/c6-c...-corvette.html
http://www.palmerperformance.com/sto...products_id=76
Former Vendor
On sale until the end of the year!! Get $40 off
http://www.palmerperformance.com/sto...x.php?cPath=32
Former Vendor
New Firmware available. This firmware has added a PID so you can set an alarm to washer fluid level (for methanol injection cars), added MAF Hz, and Vehicle voltage.
http://www.palmerperformance.com/dow...ware_v1.17.ehx
Former Vendor
Cardinal Flyer (02-22-2018)
If you have NPP and don't order one of these, you're missing out. Stealth mode to ridiculously loud in the flip of a switch. Even with long tubes and no cats, the factory muffler makes it purr like a stocker.
I see that you use the lock button to scroll through the displays and the mirror button for exhaust selection. how does this work with the buttons original function? like will the locks pulse every time I cycle displays and will my exhaust have to be open while I adjust my driver mirror? cant seam to find any instructions for the dash logic to look through. thanks in advance.
