driver side power seat stopped working '05
Drivers side power seat stopped working. This is what I've tried so far:
Checked fuses and relays, all good. I put the driver side switch and control module on the passenger's side and they both worked fine. What am I missing? I've tried the search engine, but there isn't anything else to try. We have memory seat on driver's side.
Thanks for any help...
WHAT HE SAID. My positive side was cracked, looked fine, worked fine (telescopic steering too) unless I was sitting in the seat. Then nothing worked. When I sat down it put pressure, and broke connection. Was hard to see/figure out. So look close.
Received 8,926 Likes
Did you check the Tele Switch MMS 10 Amp fuse in the BCM? Seat won't work if the memory module doesn't have power.
Bill
Bill
power seat
I'll be damned. Thanks Bill!!!!! Who would think that a telescopic steering wheel fuse would have the control module for the seat included in it. Seat is back in working order!!
