Corvette problem losing power
Old Mar 7, 2014 | 09:47 PM
Newman007's Avatar
Newman007
1st Gear
Default Corvette problem losing power
I own a 2005 corvette ls2 automatic. I pulled away from a stop light and felt a slight shudder in the rear end. The car suddenly felt as if it only had slight power to the rear wheels. The engine revved fine and was not overheating. The car finally came to a stop in overdrive and would not move. Thinking of computers i turned the car off and then restarted. The car was fine again for about 1 mile then same thing. This car has 45000 miles and normally runs and drives like new. Had a mechanic come over with a scope and no error codes. Any suggestions ?
Old Mar 9, 2014 | 11:13 AM
tennblkc6's Avatar
tennblkc6
sounds like torque converter maybe. have you checked the fluid?
