C6 won't crank or start
Lately I have only been driving my c6 about once a week. I drove it to work yesterday ( about 20 minutes each way) and everything was normal. Then this morning I went to start it up and the electronics come on but the engine doesn't even try to turn over. My voltage (Optima red top) shows 11.8 volts. I tried jumping it but it didn't help. There is an engine light on but that my be because the engine didn't start.
I tried disconnecting the battery to reset the computer butch that didn't help. I also checked for codes, but there aren't any. I just dropped the battery off at a shop to test it and see if that is the issue.
Any ideas would be helpful.
Thanks, Charley
Thanks, Charley
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is the STARTER circuit for a C6. You can jump around the THEFT DETERRENT Relay and see if its a security issue preventing it from starting.
it was simply that the battery charge was too low. That is a little strange because I just drove the car to work yesterday..... But I got the battery charged and tested and the battery tests fine and now the car starts.
Thanks for the help,
Charley
Charley
I'm not convinced that you have found the problem yet! Just covered it up with fresh charge. Maybe something left on or plugged in
Interesting - I have a '12 and I've gone 2 weeks without driving it with absolutely no issues about it craning right up on the first touch of the start button.
The Optima Red tops used to be AWESOME batteries, but several years ago (2009/2010 if i remember) they moved all of their manufacturing to Mexico and their battery quality has become absolute garbage. I highly recommend swapping that Optima out for something else.
