Cray Wheel problems!!!!
Old Mar 21, 2014 | 05:27 PM
rdarmond's Avatar
rdarmond
1st Gear
Default Cray Wheel problems!!!!
Need help. Have new set of Cray Manta wheels for my 2006 base conv. TSMS are mounted on inside of wheels and hit tie rod and breaks off the tip. Car is stock no mods. Stock 18x9's. Anyone have a answer? Thanks Ronnie
Old Mar 21, 2014 | 10:02 PM
Jrockk's Avatar
Jrockk
Gotta be the wrong offset unless your running really long valve stems
Old Mar 22, 2014 | 01:33 PM
96mogt's Avatar
96mogt
I ran these same exact wheels with zero issues. Possibly like Jrockk stated, wrong offset. Jay
Old Mar 22, 2014 | 04:31 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Not sure what you mean by "TSMS are mounted on inside of wheel...". Maybe I'm missing something here, but if you're talking about the pressure sensors/valve stems, they're mounted on the outside of the wheel. Unless you mean the wheel weights & in that case, there should be plenty of clearance. I have the Manta's on my '05 Z51 with no clearance problems & don't recollect anything other than the standard offset. Have you called Cray to see what they say?
To Cray Wheel problems!!!!
