Oil change
Old Jul 12, 2014 | 12:29 PM
gmtech1234's Avatar
gmtech1234
Default Oil change
I bought my first Corvette, pick it up next week. I want to change the oil ( it looks good, but I am **** ). I have floor jack & stands. What do you use to raise your car & where do you lift it at?
Old Jul 12, 2014 | 01:29 PM
Freak3150's Avatar
Freak3150
For oil changes I raise the car one side at a time with a jack at the front frame lifting point near the front of the door (with a hockey puck as a pad between the jack and frame), and set it on some Rhino Ramps.
Old Jul 12, 2014 | 02:17 PM
gmtech1234's Avatar
gmtech1234
How high are your ramps?
Old Jul 12, 2014 | 03:43 PM
Freak3150's Avatar
Freak3150
According to their website, 6.5 inches.
Old Jul 12, 2014 | 04:13 PM
gmtech1234's Avatar
gmtech1234
Is this high enough for the oil change, can you get to the filter & drain plug?
Old Jul 13, 2014 | 06:16 PM
StKnoWhere's Avatar
StKnoWhere
Yes, they are behind the driver side front wheel, very easy.
It can be done without getting under the car by removing the wheel.
I refer RaceRamps since the ramp can be easily removed once the car is in the air. Very fast and safe.
Some info on jack & stands placement.
http://www.bugmanweb.com/c6/jack.html
To Oil change
