Check Engine codes help!!!
Old Oct 9, 2014 | 10:50 PM
cedp83's Avatar
cedp83
Default Check Engine codes help!!!
Keep getting codes P0300 Random misfire and P0171 system too lean bank 1. The car shakes (with a really strong gasoline odor) only at idling and/or chokes when starting on 1st gear from a stop, no issues under acceleration, down shifting, etc, the car feels responsive otherwise. So far I've put new plugs and wires, cleaned the MAF sensor, air filter, throttle body and checked for vacuum leaks. Mods are Vararam CAI, LT headers, Diablo tune, all done approx 3 years ago without any issues afterwards. Suggestions are appreciated. Vette is a 2005 with 89k miles on the clock btw. Thank you!!!
Old Oct 10, 2014 | 09:43 AM
shawnaj7731's Avatar
shawnaj7731
Sounds like abad oxygen sensor
Old Oct 10, 2014 | 08:07 PM
truckplay's Avatar
truckplay
check fuel pressure and do a compression test on the driver side cylinders.
Old Nov 17, 2014 | 08:21 AM
cedp83's Avatar
cedp83
Ended up being front O2 sensor, thanks for the help gents.
Old Nov 17, 2014 | 08:54 PM
VET4LES's Avatar
VET4LES
Good news.
To Check Engine codes help!!!
