D3 Performance Engineering C6 Dual Spal Fan Shroud Kit
D3PE, here's a setup I made for my car. Much more room for superchargers and can be cut down 2" for the dewitts radiator. I was able to move the fans out and down because my shroud sits on the edge of the tanks instead of the inside. No shown, but I clocked the left fan motor 90 degrees for more clearance on the sway bar. Making them this way, might appeal to a bigger market.
my DeWitts Spal fan set-up dropped right in on the factory mounts and the fan plug plugged right into the control box, The Spal shroud is plastic and it has the same little vents with the same little rubber flaps as yours does, in fact they "look" the same except yours is aluminum, I am always trying to improve things especially cooling so I'm just trying to grasp why it's better? Thanks
You need to look at these under load
This dual fan set up here by D3 flows 2,680 cfm (1340 x 2) at 15 mm of restriction whereas the spal 2 x 11 flows 1,770 cfm. So 50% more flow using the 15 mm restriction. However does take more current 56 amps versus 35 amps. People get caught up in the free flow that has nothing to do with it (unless you have nothing in front of it). These cars have a radiator, ac condenser, oil cooler, and intercooler for some people - this all causes restriction and can severly eliminate flow from a low powered fan. In fact at 20 mm the difference is even more with only 1263 cfm for the dual 11s versus like 2400 cfm for these - pulling 60 amp though.
Like posted above, CFM without a restriction means nothing.
If my car runs around 225-245 with AC on in 100 degree weather cruising at 80-85mph, how much should my temps drop after installing this setup?
Car is a ERL 427 with a Novi 1500 and ECS SC intercooler kit.
80-85 mph
The fans will not help too much as Unreal said by that speed the air should be pushing through at that point. The D3s are very helpful for under 40 mph with all that stuff you have in front of it. No one thing I noticed on mine is that it runs cooler in 5th gear than in 6th by about 10-15 degrees in that speed range you are talking about. I am not sure if it has to do with water pump speed or the engine lugging at a lower rpm but it runs cooler in 5th. Now I am naturally aspirated.
Great info in this thread. I have an A&A t-trim kit coming for my c6 z06 and I am looking to upgrade the fan setup. I know that A&A's kit comes with a different radiator (not dewitts) so I was wondering if anyone knows if this will fit? It's slightly thicker but not sure on size. If I remember correctly, their kit does utilize the stock fan units, just not sure how much modification is necessary to get that on that would need to then be done to this kit. Thanks for any help as this restricted flow increase will really help me in the summer down at the beach and slow cruising in traffic.
#34
#35
THis looks to be the ticket for those hot 117+ degree days here in Phoenix
#36
