Tpms question
Has your car had the Service Active Handling recall/TSB service done, to install the clip on the connector in the steering column? If not, see the Service Active Handling Consumer Action sticky at the top of the Tech Forum.
The "XX" for the TPMS usually means a communication problem or, considering the age of your car, a failed TPMS battery.
https://www.corvetteforum.com/forums...l-10118-a.html
With all the TPMS being around the same age, just buy 4 New OEM TPMS, and have them changed all at the same time.
Note, TPMS sensor in in the wheel/rim, and do not confuse it with the wheel speed sensor.
As for the rest of the messages, if you have a telescoping steering wheel, then there is a safety recall since it can disconnect the harness in the steering column to cause these problems.
If no telescoping steering wheel, then pull the trouble codes (auto parts store will pull this for you for free), and post back with it. Hence the problem could be as simple as one of the wheel speed sensors connector loose or sensor on the way out.
To add, if you have after market braided brake lines, can cause the same problem with static charge to the wheel speed sensors as well.
