G1 Swaybar Install
Old Jan 20, 2015 | 11:25 AM
TRYAGN's Avatar
TRYAGN
Cruising
Default G1 Swaybar Install
Installing G1/T1 swaybars in my C6Z and have run into a problem with the bushing and bracket. The size of the bushing will not allow me to fully tighten the mounting bracket to the frame of the car. I have researched this and the only thing I have found is that washers should be used to shim the open space. Also found this does not occur on all cars which is very odd to me. Wanted to see if other have run into the same issue.
Old Jan 20, 2015 | 02:09 PM
ErnieN85's Avatar
ErnieN85
yes common problem put enough shims in to make the bar rotate free when clamped
Old Jan 20, 2015 | 03:25 PM
timd38's Avatar
timd38
So why is it only a problem for some, but not all?
Old Jan 20, 2015 | 03:30 PM
ErnieN85's Avatar
ErnieN85
mostly beecause of varying bushings and bar tnickness.
the outside diameter is the same but when you put in a thisker bar you need a bigger opening and the bushings are not uniform
To G1 Swaybar Install
