Modifying daily while staying within CA Emissions? 06 A6
I've been loving my C6 and have recently been looking for some more power and sound. My only concern is if it will no longer pass smog for CA. It has been my daily driver for some time so I don't need a monster, just a bit faster than stock. I've read a dyno tune is the best bang-for-buck mod so I'm considering taking it to West Coast Corvette. My only concern is if it will no longer pass smog for CA. Anyone see any problem with any of the below? thought I'd ask some experts before finding out the hard way!
Currently I have:
K&N Cold Air Intake
Z06 Bi-Mode Mufflers
Considering adding:
Vararam Power Wedge/Spacer
West Coast Corvette Full Tune
LS7 Exhaust Swap
Currently I have:
K&N Cold Air Intake
Considering adding:
LS7 Exhaust Swap
The LS7 exhaust swap is a good way to gain some better exhaust flow and retain a look that will pass visual inspection.
I don't put much faith in TB spacers.
You didn't say what year you have. If you have an LS2, porting the TB and intake manifold are not too expensive, maintain a stock look, and should add at least 10 HP and 10 TQ. An LS3 can also be ported, but on an otherwise stock motor don't see as big gains.
A tune is a good idea. I'd do the mods first so that the tune is based upon the car after the hardware changes.
You can also do a mild cam and still pass the snifer test. WCC can help you select a cam that they know will pass the tailpipe test.
In CA, any mod/after market part you do to the car has to have a C.A.R.B # so it will pass the visual part of the test as a Ca approved after market part.
http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
You might get away with the Z06 exhaust manifolds and cats if the inspector does not notice them, but then again, you may not since they did not come OEM on the LS-2/LS-3 motors if the inspector does notice them.
So before you start adding after market parts on a CA car, make sure that the parts/mods has a C.A.R.B#.
Note, the E-force 600HP superchargers have a C.A.R.B. #, hence D-215-85 and is a legal mod in CA.
Currently I have:
K&N Cold Air Intake
Considering adding:
LS7 Exhaust Swap
Currently I have:
K&N Cold Air Intake
Considering adding:
LS7 Exhaust Swap
BTW, it's not a CAI, K&N has never made a CAI for a C6.
Currently I have:
K&N Cold Air Intake
Considering adding:
LS7 Exhaust Swap
Currently I have:
K&N Cold Air Intake
Considering adding:
LS7 Exhaust Swap
Honestly clean power...
If you really want to make honest power in CA and do just about everything you want switch over to E85 like I did yesterday Though I'm not in CA.
Because it cost money to get a CARB #, plus part of the stock intake is a noise reduction system, and may not allow the device to get the Carb# if also does not reduce intake noise.
As for headers, the glitch here is that it moves the location of the Cats farther down stream, and why no one has a Carb # for long tube headers
Note, shorty header do have a CARB #, since it does not move the cats farther down line that those on a Z06. So instead of a z06 system that may not get through inspection, these shorty headers will have a CARB # to pass inspection, and will give you the same gains as the exhaust manifolds on the ZO6.
I do not think anyone will be the wiser regarding the Z06 manifolds on the LS3. The important thing is the cats are in the correct spot and the manifold itself looks like a stock unit (as compared to long tub design).
Yes I know it is not kosher as far as the air resources board is concerend. Codes are all in "ready" mode when tested.
I'm sure the shorties will be at a premium over the Z06 system cost wise.
Also while the Z06 system offers good gains in the hp area it does fall significantly short in matching the gains regarding torque, as compared to true long tubes.
I solved this with the addition of steeper gears, 4:10.
http://arb.ca.gov/msprog/aftermkt/de...o/D-269-31.pdf
