C6 manual tranny spinning noise
So this may be the same common noise, but I did not find anything that was specific to the noise I hear. Just bought a 2011 c6 coupe, 11k miles. When leaving an intersection, after 1st gear is engaged ( ie you are rolling and clutch fully released), I hear a spinning noise for the first few seconds. Usually is gone by the time I cross the intersection. Sounds like if you had a loose ring on a rod and spun the ring. Is this normal and what people refer to the marbles in the can? Clutch engages fine, no squeals or grinding shifting gears.
Mine has sounded like marbles rolling around in a can from day 1. Not sure if yours is the same but mine is a common complaint. It helps to leave with more rpm.
sorry can't help, my 06 is dead quiet and after a broken pin{kept me from going in reverse} the dealer replaced the tranny with a 07 still no "marbles in a can"
All of my manual transmissioned cars/trucks that I have had in the last 25 years have had gear rollover noise and that include my C5Z and my C6 Base. Some were worse than others. Don't lose sleep...enjoy the ride.
