C6 Ls7 Heads and Cam Swap job with full Pics
I'm not doing a cam swap yet. I have bolt ons- headers, cai, and a tune. My problem is I wanted to remove the builders name plate on the fuel rail hold down brackets as per your step 5. But the bolts don't come out because they hit the cowl. I'm assuming you have to remove the intake with those bolts left loose in the intake? Something I didn't want to do just to remove the name plate.
good writeup and lots of pics. rpmextra.did my swap last Sept.kinda intimedating for some novice but it can be done just time consuming.double triple check your work and the end youll have a big smile on your face knowing you did it yourself.
Loving the results so far PB 10.57@137mph with +2300DA
here is a 10.58run
Great write up... I have done heads and cams on other vehicles but I have been a bit apprehensive on doing it on my GS not knowing how involved it would be... your write up made it look as straight forward as doing heads and cams on any other vehicle so I feel better about doing the work myself now.
Thanks for taking the time to put this together!
SPEED SAFE, NICK
SPEED SAFE, NICK
#33
SPEED SAFE, NICK
SPEED SAFE, NICK
Very Happy to hear that you find this helpful. That was my #1 intention.
#36
This needs to be stickied in the Z06 section!
#38
Ah I see kinda far away.just wondering checking if your in the same area looking for Arun@CCP-canadian corvette performance.running his stage2 blower cam on my setup.might try give Champion Motorsports a call.heard his overthere now.worth a try. Thanks.
