Is it usually a fulty gasket that causes oil pan leak?
Just wondering I see alot of the C6 vettes have or have had oil pan leaks. Mine does as well with only 19k on it. Anybody really know the cause of the problem? I understand the gasket is not sealing but is it a bad design of the gasket or something with the oil pan? For you that have had the leak fixed how did it hold up? Do they have an updated gasket or something or should we expect to have the leak start again after a few thousand miles? Just wondering what the root of the problem is.
My research (thanks to a leaky `03 Yukon) into Gen III oil leaks says it's an issue with either a porous pan/cover or block, sometimes all of the above. It causes the gasket to start leaking over time and it just gets worse. If the pan is porous it needs to be replaced, if the block is then the mating surface needs to be cleaned, RTV used to fill in voids and after setting up for ~10 minutes a new gasket is installed with the pan.
From my experience and research the issue is very common on the iron block 4.8, 5.3, and 6.0 trucks; especially with the rear cover leaking, which is expensive to replace labor wise. With the aluminum blocked LSxs and 5.3 the issues seems less common and often it's the oil pan when it does happen. Granted my sample size is small: 4 LS1s, 1 LS2, 2 Al 5.3s, 1 iron 5.3 and 1 LS3 (dry sump), but the iron 5.3 is the only one that leaks and it's pan and cover.
My buddy who's done quite a bit of work on Gen IIIs made a similar conclusion; most LS cars seemed to be reasonably clean underneath while the trucks were usually filthy.
Bought a 07 last year with 17,500 miles on it. Near the end of the summer I started to get a small drip from the oil pan. After doing research on the Forum I found it was a common occurrence and most said to try to re-torque the pan bolts. I did that and the leak stopped. This year it started to drip again and I torqued the bolts and it stopped again. Not sure if this will help but it is definitely the cheapest repair.
Good luck
Good luck
Received 1,194 Likes
St. Jude Donor '15
For real..I noticed the same thing. I guess ugly was cheaper for GM? Geez.
My 08 seats, not to the point of dripping. I clean it every oil change.
I have checked torque which were fine.
I just did an oil pump on my Avalanche, that block and oil pan surface were better than any engine I have worked on to date. I would believe faulty gasket if the bolts are not lose.
DJ
DJ
St. Jude Donor '15
True.
