Harmonic balancer failure
Old Jun 11, 2016 | 11:54 PM
  #41
Never9Fast3Enough's Avatar
Never9Fast3Enough
Originally Posted by irok
or you could use the 2 proper factory Kent Moore alignment tools J 41480 and J 41476
I think I can get access to these tools. Any special suggestions as to there use?
Old Jun 15, 2016 | 05:30 PM
  #42
Never9Fast3Enough
Couple of more dumb questions. I might be over my head with this repair, but with parts laying all over the garage it is a little to late to worry about that.
Why do I need to loosen the timing chain cover to center the seal? Can't I just assume it was right from the factory and install the new seal?
What is the proper orientation of the seal? My seal came out with the balancer, but it was loose and I failed to observe the orientation. When it is installed should I be looking at the flat side or the cupped side?
The factory balancer had some type of plastic/rubber and metal ring that fit between the balancer and the crank. Actually the crank fits through this. The new summit balancer does not have this and it doesn't look like the original would even fit on the Summit balancer. What to do here?
Thanks in advance!
Old Jun 15, 2016 | 06:11 PM
  #43
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Thanks in advance!
I've replaced a balancer and seal without loosening the timing cover bolts before and the car didn't leak, but others have done the same and it did leak so this is your call here.
You should be looking at the flat part of the seal and you can do without the friction washer especially if it doesn't fit.
Old Jun 18, 2016 | 08:56 PM
  #44
Never9Fast3Enough
Big thanks to all of you for your advice and assistance in this job. Car is back together late today and there are no leaks or issues. Time will tell if there will be any seepage from the timing cover seal, but I am going to be optimistic for now. Thanks again to all!
Old Jun 19, 2016 | 07:03 AM
  #45
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Old Jun 19, 2016 | 10:22 AM
  #46
C6smackdown's Avatar
C6smackdown
I have replaced no less than 75 front covers on LS motors and have never used an alignment tool. Nor have I had one leak. Put a small bead of RTV on both corners of the oil pan gasket where the front cover gasket and pan gasket meet. Leaving the front cover bolts loose, install the HB. Tighten the front cover bolts. Make sure the gap in both lower corners of the front cover are equal. AFTER you have tightened the front cover bolts, you then tighten the two oil pan bolts.
Make sure you bake the balancer in the oven for 10-15 minutes at about 180*. Also, put antiseeze on the crank snout and hub of the balancer. It will then slide right on.
And never ever replace the HB without replacing the crank seal. You will regret it.
Old Jun 20, 2016 | 09:32 AM
  #47
irok's Avatar
irok
Default this
the best explanation of their proper use is found in your factory service manual on page 6-92 of the 05 manual and found on different pages in other years which shouldn't be too difficult to find on line here
