Antifreeze
Antifreeze
Living in the southwest, when seldom do ambient temps go below freezing, has any on run a higher water ratio to antifreeze? If so, what was your experience?
I just did mine, I went with the recommended 50/50 mix as close as I could get it with DexCool. Lots of comments both negative and positive about the product but its what GM recommends so that's what I used.
My car seems to actually run a tad cooler that it did before but also probably my imagination, just to justify doing it
NSF
NSF
dmoneychris (04-20-2016)
Living in the southwest also means HOT temps in the summer. Antifreeze not only acts to lower the freezing point of water in the winter....it RAISES the boiling point of water in the summer. Additionally, a 50:50 mixture provides better heat transfer from the block to the cooling medium and ultimately, to the radiator, not to mention the points of corrosion protection and water pump lubricant from the poster above.
Not So Fast (04-18-2016)
Received 2,060 Likes
I'm using somewhere between a 30-70 and 35-65 antifreeze to water mixture. I changed to that ratio toward the end of last year, so I won't have any definitive results until the early afternoon temperatures here are consistently in excess of 100 degrees. The highs are only in the mid 90's now and probably won't hit 100 much before May. It'll be June before I can tell the difference.
At a 30-70 mix, the boiling point is 259 vs a 50-50 at 271. Since the highest I've ever seen was in the mid-240's, I feel confidant that a 30-70 mix will be safe. The car has never been subjected to temperatures below 20 degrees, so freezing is not a concern.
25 dexcool/75 distilled water and a bottle of Amsoil Coolant Boost(similar to water wetter I am sure). This was recommended by my Amsoil sponsoring dealer who is on here.
Car runs ~190, nice and cool.
My tune also has the fan come on quite a bit earlier.
Like HOXXOH says, boiling point is reduced a little but the car should go into reduced power before that occurs. Im seeing conflicting reports of 250-260 the car will go into reduced power mode OR be pulling timing like crazy due to a hot engine to essentially reduce power. Anybody know exactly what temp the ECU commands this?
Like say we were both driving alongside one another, same speed, temperature and all other valuations, would my car run cooler than yours because I had a higher concentration of coolant ???
NSF
I understand your thinking absolutely, my question is does the 50/50 mixture make your car run cooler than a 70/30 one does??
NSF
NSF
straight water is going to transfer heat far better than anti-freeze/water mix.
BUT with straight water you lose: low temp capabilities, corrosion protection, increased boiling point, lubrication for water pump.
Straight water is ok in a race car because the system is changed out a lot and cooling ability is FAR more important than anything else.
On a street car that runs 50k+ miles(or FAR more) on a fill, losing the anti-freeze and what it adds to the system is far more important than the little bit of extra cooling you get from straight water.
St. Jude Donor '11, '14
Use distilled water do not use regular water.
160 thermostat.
Water wetter or other brand.
I used water wetter when I raced. It worked well.
No need for reprogram of fans. I live in Fl. Ac on all summer so why reprogram fans that are already on when it's hot!
Robin
160 thermostat.
Robin
Phoenix alone averages 11 days a year over 110 and it's not the hottest place in the State. The State record is 128 in NSF's backyard.
It always make me chuckle when people in FL think it gets hot there. The all-time record high for the whole State is only 109 degrees. Only the New England area has lower records than FL.
It's "dry" therefore it does not seem as hot........
From my understanding with the A/C on the fans won't go to high speed until the temps go up. My 95 when I put the a/c on the fans went to the high speed. The C6 has variable speed . The 160 on my 95 worked great as it averaged 185dg temps ( in Florida). For now I'm leaving the C6 stock. What are your temps with the a/c on in traffic and highway with the 160 stat?
Received 1,193 Likes
St. Jude Donor '15
Fans will come on when AC pressure gets to a certain point or ECT gets to whenever it's setup to come on (doesn't change based on AC on/off).
Whichever commands the higher fan % (between AC and ECT) is what is used
The Colorado River valley is frequently the hottest place in the US...Bullhead City, Havasu, etc etc...much hotter than anything in Florida. I remember coming out of a casino in Laughlin one time at 2:00 in the morning and it was still 108 degrees...brutal. Death Valley is the all time record though...
