Stock ride height adjusters bolts worn out... now what?
The rubber pads on the bottoms of my original-equipment "lowering bolts" have disintegrated into nothingness. The metal bases of the adjusters are now bearing directly on the lower control arms. As you can imagine, the car is riding lower than it used to.
GM in their stubbornness won't sell me new adjusters unless I spend $700 for brand new leaf springs that I don't need. That leaves aftermarket bolts, but I'm always seeing complaints about how quickly they wear out.
Given that the aftermarket is my only option, can anybody recommend a brand of lowering bolts which
- last a long time and
- have sufficient adjustment as to be suitable for a more-or-less stock ride height?
New OEM style ride height adjusters now available from a Vendor,
There is a God!!!!!
There is a God!!!!!
-jp
I ordered the Corvette Central reproduction adjustment bolts last Thursday. They arrived Saturday and I installed them over the weekend. Got the car as dialed-in as I can without corner weight scales. Now it's time to take it to the alignment shop.
The Corvette Central bolts appear to be copies of the OEM rear bolts. Corvette Central sells the same part for use in the front or rear. The OEM bolts, on the other hand, have a smaller diameter rubber pad on the fronts.
My OEM bolts were in bad shape after 132K miles, particularly the left front, which had disintegrated completely. I'll let you know how the new ones hold up.
A question if I may:
Using the (larger pad - rear style) Corvette Central bolts on the front, did the bolts wind up at the same location on the threads? Meaning - would they have allowed the front ride height to be raised? I'm having trouble raising my car after a blower install, it's maxed out on the stock bolts.
TIA
TIA
TIA
TIA
The Corvette Central bolts are copies of the OEM rears. With rears installed in front, the larger-diameter pad will engage the control arm at a slightly more inboard position. This will probably raise the ride height a little, but on the other hand it will probably settle down as the pad conforms to the arm.
The Corvette Central bolt also has about 1/8" less hex at the end of the bolt and therefore about 1/8" more thread length. This will buy you a little altitude, but not much.
With the Vansteel/ hardbar design you can just buy longer bolts if they dont get the height you need
https://www.vansteel.com/index.cfm?f...p=1951&ID=3476
Chiselchst (07-13-2016)
If somebody were to combine that removable bolt design with an OEM-style base pad, that would be perfect (and easier to install). Basically have a nut welded to the base instead of a threaded rod.
Great information. I ordered the ones at Corvette Central, and this is the info I received:
PN 575020
Pad Diameter 2.25"
Pad Height 1"
No OAL.
Then they have these Derlin padded ones, from LPE - with the following specs:
2.195" Pad diameter
.366" Pad Thickness
No OAL...
Thanks to "el es tu" post above, I also ordered the Vanstar Delrin ones, they are 80MM in length. They have ones to lower the car, that are 60MM. You have to remove/smooth the A arm to provide a smooth surface for the bushing to contact/rub against or the Delrin will crack.
Does anyone know the stock OAL?
A friend from work had the same issue on an earlier year (C5?), and he used a Dremel tool to make a smaller bolt pad fit inside of a resized larger pad, then epoxied them together.
PN 575020
Pad Diameter 2.25"
Pad Height 1"
No OAL.
2.195" Pad diameter
.366" Pad Thickness
No OAL...
It's been a few years. Can anyone comment on how they like any of the ride height bolts shown/discussed in this thread? I'm to the point where I need to make a decision which route I'd like to take.
Problem is the end of the ride height bolts see a lot of pressure, and most of the low profile after market tips just break off quickly/need to be replaced with about a year.
The oem's are rubber section ended, and although will compress and wear out of time, it a long time before they have to be replaced isntead.
I think the Van Steel parts are probably the best option. I have a set for when my stock ones wear out. When I do change them, I work out a way to attach some high density rubber to the control arm where the delrin ball contacts so that it will cushion it some.
