2015 Sabelt GT-140 FIA Race Seats on sale
Former Vendor
St. Jude Donor '13
We have a limited number of 2015 Sabelt GT-140 FIA Race Seats in Large ONLY
MODEL: GT-140
The GT-140 uses a proven motorsports design with great side, lateral, and shoulder support.
Sizing Advantage:
Instead of using one shell with different padding / foam inserts, Sabelt has produce a medium, large, and extra-large shell to better suit a drivers position and body type. By using a unique shell for each size, Sabelt has also been able to reduce the amount of padding needed to fit smaller drivers (Padding can add 3+ lbs. to a seat)
Compatible with 3, 4, or 6-point harnesses
CONSTRUCTION: FIBER REINFORCED PLASTIC (FRP)
Gel-coated FRP construction allows Sabelt to produce a complete range of full bucket seats, with individually sized shells to meet the needs of various drivers and body types. FRP material is also used for its’ strength characteristics while maintaining an economical price point. All Sabelt full bucket seats produced using FRP do meet the safety requirements for FIA certification.
NON- HEAD ENCLOSURE
The standard race bucket design provides an increased range of vision while driving, and is easier to get in and out of.
HARNESS SLOTS
Larger harness slots allow greater adjustability and routing of the harnesses to aid in driver comfort and safety, especially important in taller drivers. Shoulder slots on the Sabelt seats are angled to follow the curve of the driver’s shoulders.
HANS COMPATIBLE
HANS compatible seats have been design to provide enough space to allow the head to be as close as possible to the seat shell with a HANS device. Without this feature the position of the drivers head with the Hans collar created discomfort.
All of the race seats in Sabelt’s program have been designed based on the specific tests and specifications provided by FIA to be used with a Hans Device.
NEW ERGONOMIC CUSHION
The traditional two pieces’ backrest and base cushion is made up of only one piece and improves the lumbar filling of seat and driver’s comfort.
DESIGN
Horizontal seams help the circulation of air and reduce back perspiration. Managing body temperature is an important aspect in any form of professional motorsport or track use, especially when ambient temperatures are higher. The priority of the Sabelt seats is to provide the structure to keep the driver safe while providing solutions to increase the comfort so that the driver’s full focus can be on performing.
LEG PADDING
Leg padding on the Sabelt seat range has been determined by the use of an anatomic OEM mannequin to determine the proper thickness of the foam for optimal driver position.
The leg padding is removable in all Sabelt race seat models. This is important for adjustability and the need of replacement on an area subject to greater wear.
There are also drivers who prefer to have custom foam inserts designed for their bodies and seating position, so the ability to remove the padding on the seat is important.
Many Sabelt models have split foam legs to enhance the movement of the drivers left and right legs. The independent movement reduces the resistance needed for the leg movement.
FOAM AND UPHOLSTERY
Sabelt seat covers and cushions are produced to compliment the ergonomic design of the seat shell. The fabric used is a porous material that prevents body movement for improved support. This is important in the case of an accident, and allows the driver to have high concentration and focus when driving.
http://www.xplosiveperformance.com/S...ck_p_3587.html
Sale priced $588.88 each.
Flat rate shipping in lower USA $75 on one seat or two.
MODEL: GT-140
Sizing Advantage:
NON- HEAD ENCLOSURE
HARNESS SLOTS
HANS COMPATIBLE
DESIGN
LEG PADDING
FOAM AND UPHOLSTERY
Former Vendor
St. Jude Donor '13
You will need mounting hardware to install in the car. Depending on your height you have a couple options
http://www.xplosiveperformance.com/C...er_p_3305.html
you will need to go along with the above
http://www.xplosiveperformance.com/S...et_p_3591.html
or you can go with this if your taller this is what we would use
http://www.xplosiveperformance.com/C...NG_p_3992.html
