LS3/L92 Rocker Arms
LS3/L92 Rocker Arms
As part of my LS3/L92 top end addition to my LS2 engine, I will need rocker arms.
As I will need to buy these (heads didn't have them), I figured I would ask those who have experience as to what are some of the better rocker arms out there for this swap? Stock? Aftermarket?
I have seen mention of Yellow Terra (sp?), but cant seem to find the details now. I've seen mention of just the trunion upgrade.
So, please school me on LS3/L92 rocker assemblies.
Thank you in advance!
KSA Aaron (08-30-2016)
The second pic above is Comp Ultra Pro Magnum full rollers, and about $600.
A bit more ($1200), and you can have the Jesel shaft rockers. The shaft rockers have never given me any issue on my other high lift, SR engine.
Are there any modifications required to run aftermarket rockers on the LS3 heads?
As in the Ultra Pro Magnums or shaft type rockers. I had to do extensive modifications to run shaft rockers on my older engine.
What issues are being reported? I do not want issues with this new build. Reliability is high on my priority list.
Bushed ones work fine. Stock rockers work fine. Just put a set of stock rockers on.
KSA Aaron (09-01-2016)
Hey Unreal - your Inbox is full...
KSA Aaron (09-02-2016)
Does your company sell a complete L92/LS3 top-end kit. Basically putting a list together of everything I need, It would be nice if I could buy it all from one vender, if possible.
LS3/L92 heads, LS3 intake, LS3/L92 rockers, etc.
KSA Aaron we do offer these items. Will you be needing any other items such as camshaft, springs, pushrods, or anything like that? I would be happy to put some pricing together for you.
Thanks for the response. Planning to use the BTR Stage II turbo cam with matching springs. I will need timing chain for an LS2 engine.
KSA Aaron if you would like to send me an email with what all you are looking for Ill be happy to work a quote up for you. My email is Aaron387@sdparts.com.
email sent...
I have a set of stock rockers PLUS a set of new bushings that I haven't installed.
PM me if you're interested.
KW
KW
