Nt05r pressure?
Old Nov 3, 2016 | 08:39 PM
bill 2010 c6's Avatar
bill 2010 c6
Default Nt05r pressure?
What pressure should I run nitto's on the street? Thanks
Old Nov 3, 2016 | 10:33 PM
CI GS's Avatar
CI GS
Recently I've been running the 345/19s on my GS at 28 psi (cold). I've run them as low as 24psi, which will turn on the low tire pressure MIL, but to be honest, I can't say that the lower pressure helps my car hook any better on the street. I really like how these tires work on my car for regular street driving. I've seen a lot of comments about how drag radials will make your car squirrelly, etc. But at 28psi, I can still pelt mine around the abundant local roundabouts on these tires, and it certainly feels a lot better than the stock GY Runflats, which had become practically suicidal on my car after I installed the blower.
Old Nov 7, 2016 | 05:40 PM
C6David's Avatar
C6David
On drs I like to run 25psi in them so the middle doesn't get worn too fast.
Old Nov 7, 2016 | 07:51 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Been running around 25psi cold on mine
Old Nov 8, 2016 | 07:30 PM
arc6's Avatar
arc6
i run mine at 30 they are 305 19r i also run them at 30 at the track . i have a guy that love nittos tell me that the more psi you can run on them the less resistance the car will have going down the track . i have no issues just my .02
Old Nov 9, 2016 | 04:18 PM
Schred86's Avatar
Schred86
I run 20 psi cold on the street .
Old Nov 10, 2016 | 08:55 AM
bumpin96monte's Avatar
bumpin96monte
I run mine at 30 cold and do nearly 100% street driving with them. With that, it hooks 2nd at any speed with an A6 and 600whp.
I did try lower pressures, and it did seem to make 1st hook better, but IMO it made the handling worse. If I had more power, id probably be more apt to run them lower, but for now I just know to ease it through 1st before going WOT.
Old Nov 10, 2016 | 10:05 AM
xBoostx's Avatar
xBoostx
I agree at 20 psi 345s hook better wore even on the street just tps light stay on.
Old Nov 17, 2016 | 06:45 PM
LEAVINU's Avatar
LEAVINU
Run 30psi cold when running around everyday and drop them down to 16psi for the 1/2 mile stuff. Still won't hook 1st even at that low of air given my power and on/off clutch.
Hook really well from a roll though even at 30psi.
To Nt05r pressure?
