Oil leak :(
Old Nov 4, 2016 | 07:53 PM
UmX's Avatar
UmX
Default Oil leak :(
so i cant see to figure out where this leak is coming from =/
front timing chain cover looks clean..
Old Nov 4, 2016 | 08:47 PM
90zcrex's Avatar
90zcrex
Oil pressure sensor dripping down back of the engine?
Old Nov 4, 2016 | 08:56 PM
timd38's Avatar
timd38
You need to clean it, then start looking.
Could be the front seal on the crank.
Old Nov 4, 2016 | 09:26 PM
UmX's Avatar
UmX
this is after the clean and one drive lol -
front of the pan and up the pass side is covered in it.. i was thinking dip stick hole
Old Nov 4, 2016 | 09:38 PM
timd38's Avatar
timd38
WOW! I think there is an O ring when you install the tube.
Old Nov 4, 2016 | 09:40 PM
UmX's Avatar
UmX
im wondering if the engine builder put a o ring in there when he put the engine back to gether, and not like i can see in there to see if one is in there
Old Nov 4, 2016 | 10:53 PM
Pitufina's Avatar
Pitufina
The oil pan can have a hairline crack. It will expand with the heat and leak like a ****. The bottom corners of the timing cover where it meets the oil pan is a good idea to use a little silicon too. You can also check the torque on oil pan bolts but be very careful.
Old Nov 5, 2016 | 03:21 AM
User Omega's Avatar
User Omega
sub'd This ought to be interesting.
I would put it up on jack stands and let it idle after a good cleaning again. Let it run for certain periods of time and then inspect with the car off. Driving it is clearly blowing the oil around everywhere. A one time drive that leaks that kind of oil will be obvious sitting still if you let it run for cycle. If idle brings no leak then rev the engine to get the pressure up and reinspect.
Old Nov 5, 2016 | 09:01 AM
UmX's Avatar
UmX
sounds good will do so once i have it running again.. what about the UV stuff you can use with a black light?
Old Nov 5, 2016 | 11:20 AM
GeneSch's Avatar
GeneSch
That is a tough one. I would think from front of motor some place. Cant see that much working its way from front to back.
Valve cover, valley cover, front cover.
Old Nov 5, 2016 | 01:31 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
I agree with timd38, thats coming from the front of the motor, likely a crankshaft oil seal. Mine looked the same way before I replaced the seal
Old Nov 5, 2016 | 01:36 PM
UmX's Avatar
UmX
Motor pull for that?
Old Nov 5, 2016 | 01:46 PM
Millenium Z06
Moderator
No but its the same as replacing the harmonic balancer. The rack has to come out, drop the swaybar, disconnct the driver side shock and both tie rods and drop the cradle about an inch, remove the balancer then get the oil seal out then replace. Its about a 4-6 hour job
Old Nov 5, 2016 | 02:03 PM
UmX's Avatar
UmX
Old Nov 5, 2016 | 02:04 PM
UmX's Avatar
UmX
I'm going to try the UV stuff first before tearing it apart. But thank you for the info.
Old Nov 5, 2016 | 03:07 PM
Millenium Z06
Moderator
Look the the motor from the top, above the balancer and just behind the balancer, also look inside the balancer at the bolt and see if oil is seeping there.
Is the oil up on the block too or just limited to underneath in the pan area?
UV wont work because of the volume of oil you have leaking, if that much did come out after cleaning and on one drive. Is is above or below the exhaust ports?
Old Nov 5, 2016 | 03:13 PM
UmX's Avatar
UmX
Mostly bottom of the block. Upper looks Clean...
To Oil leak :(
Old Nov 5, 2016 | 04:10 PM
HOXXOH's Avatar
HOXXOH
Sounds like "the engine builder" should be revisited and questioned. How long or miles has it been since the install?
It appears that the dipstick tube is already out, so checking it should be easy. Of course, if you never removed it when you pulled the exhaust, then the cause of the leak is obvious that the tube was never installed.
Old Nov 5, 2016 | 04:23 PM
UmX's Avatar
UmX
I pulled the dip stick out and there is a lil rubber grommet on the dipstick and nothing at the hole in block...
About 10k on motor now.
Old Nov 5, 2016 | 06:42 PM
User Omega's Avatar
User Omega
You do not need to drop the cradle or pull any shock side. Just put the car up on jack stands, drop the sway bar down, unhook the two PS lines, remove both ball joint ends from rack, remove rack mounting bolts, slide rack out passenger side until you have clearance. Then you will have access to the balancer. Remove the puller and install new seal.
