How do I check clutch ?
Old Feb 2, 2017 | 09:37 AM
LEJ ZO6's Avatar
LEJ ZO6
Default How do I check clutch ?
I have a 2008 ZO6 that I bought new. It now has 90,000 miles on it.
Lately I have noticed a hesitation when accelerating medium to hard.
At first I thought it might be plugs or wires. No check engine light, no codes, nothing when driving with a monitor hooked up. I changed the plugs and wires anyway and the engine runs really good but I still notice this hesitation on acceleration.
It doesn't always do it and it isn't always at the same rpm or throttle position. I suspect that maybe the clutch is wearing out. Is there a way I can check the clutch condition without pulling the whole thing out ?
Old Feb 2, 2017 | 11:11 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
A quick and dirty test would be to put it in a high gear at a low mph (like 5th at 30 mph) and floor it to see if the clutch slips.
Old Feb 2, 2017 | 03:41 PM
cclive's Avatar
cclive
And hesitation is not really a symptom of a clutch going south. Slipping is that symptom. So unless you hear/feel the engine rpm go up when this hesitation happens, it's not the clutch.
Old Feb 2, 2017 | 04:19 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yeah, symptoms don't really match. Slipping = RPM's will shoot up but you don't accelerate at the same rate.
Old Feb 2, 2017 | 05:49 PM
extrapilot's Avatar
extrapilot
and sometime accompanied by a burnt odor like when sometimes you get behind a tractor trailer with brakes dragging.
Old Feb 2, 2017 | 09:45 PM
cclive's Avatar
cclive
Yup, a slipping clutch smells like burning brakes...very expensive brakes.
Old Feb 3, 2017 | 11:14 AM
LEJ ZO6's Avatar
LEJ ZO6
I took a ride this morning and tried your suggestion.
No slippage. I guess it must be something else.
I'll keep looking.
Thanks for your suggestion.
Old Feb 3, 2017 | 11:16 AM
sevinn's Avatar
sevinn
I'll keep looking.
Glad to hear it didn't slip for you. It isn't a guaranteed clutch is good/bad test but it will normally tell you if one is definitely bad. I always get very nervous before running that test
I think you should do some data logging to see what's going on with the hesitation. Could be something as simple as a dirty throttle body sticking.
Old Feb 3, 2017 | 11:42 AM
LEJ ZO6's Avatar
LEJ ZO6
Yea, I forgot to mention it but the dealership ran a compression test and cleaned the intake and injectors while it was in for plugs and wires.
Of course that was an additional charge.
Old Feb 5, 2017 | 12:00 AM
1hander's Avatar
1hander
if the problem started after they worked on it, it almost guaranteed they messed up something..
To How do I check clutch ?
