Viking Smooth body settings
Old Feb 11, 2017 | 02:53 PM
nenji01's Avatar
nenji01
Default Viking Smooth body settings
i just put on viking shocks and found really limited info on settings on the forums i put them at c:8 r:12 in the front n rear c:6 r:10 i got from a post here made by ANGRYZ but that was i 2015 the car rides good with does settings but what are you guys running for drag racing specially highway rolls and post your power range aswell so i get a good guide to follow
Old Feb 11, 2017 | 04:33 PM
Unreal's Avatar
Unreal
Instructions that came with them are great bsaelines. From there test/tweak.
Old Feb 11, 2017 | 06:18 PM
nenji01's Avatar
nenji01
Yeah i figured i also saw what you had which was like 4/12 but u weren't 100% sure and another guy had 4/8 & 3/5 so its all over the place lol so i put the closes one to a drag setting on their sheet thinking the settings they sent were universal the car feels good but i wanted to see the settings some guys have to cut down on the tweaking. Not only that but it might help more guys like me that really couldn't find any good info
Old Feb 12, 2017 | 09:59 AM
Unreal's Avatar
Unreal
Depends on car, setup, tires, surface. You test and see what works. I'm currently running the rears at 12/16 and fronts a lot softer because the tires I have on it rub if it squats too much. So instead of rubbing on the fenders, I want to limit squat. It takes <30 seconds to adjust them, so try it, if you aren't happy, turn the **** and try again. If its floaty or you feel oscilations, or if it squats too much, add more compression and rebound.
To Viking Smooth body settings
