VMax Throttle Body - Opinions
Just curious if anyone has any real world experience with the VMax throttle body available for our C6's.
Did you notice any difference in your butt dyno? Any increase in throttle response, etc?
I have a Vararam intake and Borla exhaust.
I'm going to get a Diablew tune and would like to decide on the throttle body prior to that.
I have the VMaxx TB on my 06 LS2 A6. I did VMax by itself with no tune for about 300 miles. I think the throttle response felt better...less lag. Then I added Hinson LT, HF cats, Callaway Honker CAI and tune from diabloLew and WOW!! I know its not scientific and I dont have any numbers to prve anything but I think the VMax was worth the money. Just my .02 hope it helps
doomi (04-06-2017)
doomi (04-06-2017)
On it's own, all it does is add a little better throttle response. Any ported throttle body will do that. I have a NW102 (which is ported/polished by default) and the throttle response was much better when that along with my cam and intake got installed. Definitely helps with shifting and rev-matching.
Just be careful if you try adding this and you already have a custom tune. I did this before my cam/intake/NW102 work, and the idle was bad and hung between shifts. It should be fine if you have a stock tune, but if not, you'll most likely need another tune to get the idle right.
The following 2 users liked this post by Must_Have_Z:
Cherokee Nation (04-15-2017),
doomi (04-06-2017)
Well, I'm sold. Thanks for the input, all!
Thanks for the heads up on the tune Must Have Z. I just installed a DiabloSport tuner yesterday and did the 93 octane canned tune. I do intend to get a Diablew tune within the next month. That's why I was curious on the TB. Wanted to do that first if it makes a difference considering it's so cheap.
I believe I'll get the TB and custom tune and get rid of my Vitesse Throttle Controller at some point.
doomi (04-06-2017)
doomi (04-06-2017)
Dave
Good info, I'll keep the throttle controller. Doesn't hurt anything and it's not worth much to resell.
I really appreciate everyone's input. You guys are fantastic!
I do have another question. And I'm a novice when it comes to aftermarket tunes so it's a dumb one.
Why can you add a throttle body on a stock tune and be fine, but have issues with a custom tune? I'm guessing it's because a custom tune is much more precise; while a stock tune covers a broad range of conditions. But I've certainly guessed wrong before.
Adding the 93 octane tune and if u have an auto, the trans tune set to firm will wake the car up !
Some turn off torgue management ... that really wakes the car up in 1st and second as tq limits the engine to 380 hp
Now add headers .... you will have more going in and more going out .... now u need a tune
drive the car for 75 miles to let the trims settle then log the car and send the log to Diablo Lew . Load the tune , drive it for 75 miles and do a wot run log , send him the log and load the one he sends you back ....
Log the car as much as you like and send to Lew to fine tune the tune
You will be happy with the result i can assure u
Dave
Pete from VM knows his flow numbers and what makes sense. I had VMax Ring and It did seem to help the low speed drivability.
be sure you check which tb you have looks like you have a 08 as i do.
When i took my TB off i have a silver blade ( ls2) 09+ seems to be gold blade but the 08 first year of the ls3 seems to be a odd one. i believe they open in different directions although i think a tuner can fix it it may cause some problems if not tuned right away.
side not even the headers i bought said 05-08 6.0
Still looking to buy one though.
ill be watching to see which one you go with one day i may do the same
