15" conversion while retaining base fenders?
Old 04-25-2017, 05:35 PM
Huckleberry1511
Huckleberry1511's Avatar
Default 15" conversion while retaining base fenders?
I know I'm very much in the minority, but I like the look of my base model/narrow body C6. That being said, as I've started adding power I feel that the need for a 15" conversion for the rear wheels will come sooner or later.
Has anyone ever done the 15" conversion for the rear spindles WITHOUT going with a wider rear fender? It could be coincidence, but I haven't seen a narrow body with it done yet.
Thanks in advance!
Old 04-25-2017, 06:17 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Seen it done. The conversion doesn't really care about the fenders. Only thing that may limit is the tire/wheel size.
Old 04-25-2017, 08:28 PM
z06scentair
z06scentair's Avatar
Member here has the setup. He doesn't frequent often but I can tell you this it will stroll! It's been deep in the 9's with a YSI blower
Old 04-26-2017, 07:41 AM
ruinms
ruinms's Avatar
I'm interested in this as well, anyone have any pics?
Old 05-21-2017, 02:43 PM
Plaincoupe
Plaincoupe's Avatar
Default E
Everyone that I've seen the tires stuck pass the fenders still... I'm interested in some that sits even in the fenders aleast
Old 05-21-2017, 09:27 PM
Last 1
Last 1's Avatar
i think u might be able 2 run R C Components rear rims and machine the face of the rear brake calipers. they will go a half inch deeper under the car that rts welds plus 275 tires
Old 05-21-2017, 09:30 PM
z06scentair
I'd just stack 2x 2" spacers on an 8" wide rim. Hell you got a truckload of those Chinese spacers
Old 05-21-2017, 09:35 PM
Last 1
Last 1's Avatar
kept it real
Old 05-21-2017, 09:44 PM
z06scentair
kept it real
Real deal right there!
Old 05-21-2017, 10:19 PM
z06scentair
A friends car with 275's
ProjectSunrise (08-10-2021)
Old 05-22-2017, 07:30 AM
Plaincoupe
Plaincoupe's Avatar
nice but see they still stuck out pass the fenders.....thats too much for my liking.those look like about 2inches or so out.
Old 05-22-2017, 07:38 AM
z06scentair
It's going to be tough myself and Last 1 just spoke this morning on the topic. He feels the only way is to run a 255 tire on a 9.5 rim.
Old 06-20-2017, 10:49 PM
ruinms
ruinms's Avatar
I'm going through this right now and just killed my brand new 275/60/15 pro radials. I have the vitesse 15x10 with 7.5 bs. I just got them on and cruised the car 3 miles. Every bump I saw smoke and rubber fly. I'm thinking about dropping Down to a 255/60/15 Or changing to 17s. I don't want wide body and love my 15s.
Any help or ideas? I have saw some people run bias ply street slicks because it naturally has less bulge/section width and the tread fits up in the wheel well.
Old 06-21-2017, 12:01 AM
Huckleberry1511
Any pictures of them mounted? Maybe you could raise the car just a bit or stiffen the rear
Old 06-21-2017, 07:05 AM
JRock636
JRock636's Avatar
spacers ftw. I ran into the issue that my car had the aftermarket extra wide fenders, which are roughly 2 inches wider than the z06 configuration, so the Z06 BS wasnt right. Had to eat up the gap with some spacers. Has been fine so far haha.
Old 06-21-2017, 07:48 AM
ruinms
ruinms's Avatar
Default Here are my pics
Old 06-21-2017, 08:03 AM
ruinms
ruinms's Avatar
I have heard that you can adjust the wheels in a touch with alignment adjustment, but i highly doubt that will be enough to help me. If you look at my picture, the rim actually is flush with the fender. The section/bulge width is the is the problem, I'm thinking a 255/60/15 drag radial. The 255 mickey measures 1 inches less tread and 1 inch less bulge than the 275/60/15. 275/60/15 = 28.2 tall 11.1 section/bulge 9.3 tread and the 255/60/15= 27.3 tall 10 section/bulge 8.8 tread.
To 15" conversion while retaining base fenders?
Old 06-21-2017, 09:55 PM
Plaincoupe
Plaincoupe's Avatar
Nice wheels! Same set I was looking at. I'm almost thinking that unless you go to an 26inch tire....those 15x10s may not tuck in.....26s may stick stick out but shouldn't rub fenders..
Old 06-21-2017, 10:58 PM
Huckleberry1511
That's a beautiful setup, hopefully you can dial it in and get it to tuck better for your sake. I would be interested in seeing how the smaller tire would work out on the rear. Any concerns with sacrificing traction with that solution? What's your power level? If you don't mind me asking. I'm on a 305/45R17 with a 17x10.5" Weld and it tucks well, but it would be nice to shave weight going to a 15x10 if the traction was similar.
Old 06-22-2017, 07:40 AM
ruinms
ruinms's Avatar
I'm Not worried about traction that much, I'm not sure on my power level. I haven't been on a dyno yet, I'm hci and plan to add nitrous soon. I think I might switch back to 17s myself. Pretty much over this, I'm gonna give these 255 a shot as my last attempt.
Quick Reply: 15" conversion while retaining base fenders?
