Question about fast 102 intake install
Old 05-29-2017, 02:37 AM
George_george
George_george's Avatar
Default Question about fast 102 intake install
I have a 12 GS and will be installing a fast 102 intake nw throttle body and fast fuel rails... isnit easy? Any instructions? Also looking for torque specs. Thanks!
Old 05-29-2017, 07:24 AM
BlindSpot
BlindSpot's Avatar
Received 1,367 Likes on 907 Posts
Torque specs:
Old 05-29-2017, 09:43 AM
Brandon619
Support Corvetteforum!
Brandon619's Avatar
Here you go, these are the manifold instructions. The fuel rails and throttle body are a straight forward install
http://paceperformance.com/attachment/35460-.pdf
Old 05-29-2017, 10:46 AM
George_george
Thank you so much very helpful! Is the manifold sequence the same for Ls3 and Ls7?
Old 05-29-2017, 11:04 AM
z06scentair
z06scentair's Avatar
Yes all use the same torque sequence. You will need to allow temps to come up and then re-torque.
Repeat this process after a few more drive cycles.
Brandon619 (05-29-2017)
Old 05-29-2017, 04:29 PM
Dano523
Dano523's Avatar
Received 3,014 Likes on 2,172 Posts
The hardest part of the install, getting the intake under the rear cowling without rolling one of the O rings off the intake runners.
So get someone one to help you to first seat the intake, since although it light, it' really a two man job to get it placed without knocking a O ring out of place.
http://www.superchevy.com/how-to/eng...-on-stock-ls3/
mikeCsix (05-29-2017)
To Question about fast 102 intake install
Quick Reply: Question about fast 102 intake install
