Heat melting wiring to starter
Old 06-17-2017, 01:22 AM
hotrod03
hotrod03's Avatar
Default Heat melting wiring to starter
Has anyone had any issues with heat from exhaust header or exhaust pipe damaging starter and wiring? 2013 427 convertible. Had to replace starter
And repair wiring.
Old 06-17-2017, 04:51 AM
User Omega
User Omega's Avatar
Yes, many users have experienced this, especially with headers. There are likely 30+ threads I would guess.
hotrod03 (06-17-2017)
Old 06-17-2017, 05:13 AM
HK770
HK770's Avatar
Default starter heat
just as a normal course of things
Old 06-19-2017, 07:28 PM
rabrooks
rabrooks's Avatar
I wrapped my headers and the wires near them for heat protection
Old 06-19-2017, 09:06 PM
debo
debo's Avatar
I wrapped my headers and wires also, so far no issues.
Old 06-19-2017, 09:45 PM
RPOWU8
Support Corvetteforum!
RPOWU8's Avatar
Also a loose connection at the starter solenoid can cause the wiring to burn up. The cable from the alternator outout goes to the starter solenoid first, then to the fuse block. If the connection is loose there, it can overheat the wiring and melt the starter solenoid plastic.
DJ
Old 06-20-2017, 10:26 PM
bdickey058
bdickey058's Avatar
My service chsrgin system light is on probably do to the solenoid or just a bad starter. Inhale my headers wrapped and a starter shield. Haven't had time to get under the car yet.
Old 06-21-2017, 01:16 PM
Must_Have_Z
Must_Have_Z's Avatar
DJ
Yep. This is why I bought a 1/0 gauge wire to connect the alternator directly to the fuse block and bypass that starter connection.
To Heat melting wiring to starter
Quick Reply: Heat melting wiring to starter
