Heat melting wiring to starter
Has anyone had any issues with heat from exhaust header or exhaust pipe damaging starter and wiring? 2013 427 convertible. Had to replace starter
And repair wiring.
And repair wiring.
hotrod03 (06-17-2017)
Also a loose connection at the starter solenoid can cause the wiring to burn up. The cable from the alternator outout goes to the starter solenoid first, then to the fuse block. If the connection is loose there, it can overheat the wiring and melt the starter solenoid plastic.
DJ
DJ
My service chsrgin system light is on probably do to the solenoid or just a bad starter. Inhale my headers wrapped and a starter shield. Haven't had time to get under the car yet.
DJ
DJ
