Nav Radio Case - Openning it up - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace
Old 07-02-2017, 06:30 PM   #21
lovinmyls1
CF Senior Member
lovinmyls1's Avatar
I just ran across this:
Supposed to have 10 brushes and made for auto....ordered it and will let everyone know if it helps.
lovinmyls1 is offline   Reply With Quote
Old 07-02-2017, 07:38 PM   #22
LV2TOUR
CF Senior Member
Support Corvetteforum!
LV2TOUR's Avatar
Looking forward to your review.
LV2TOUR is offline   Reply With Quote
Old 07-16-2017, 09:43 PM   #23
Kenny94945
CF Senior Member
Kenny94945's Avatar
I opened my case today.
My issue was that I could not figure out how to remove the front screen and surround.
Before removal I ejected the CDs from both slots and then closed the front screen.
Unsure if leaving the screen open would be an option during removal and unsure if an open screen allows for the front screen and surround removal.
Without removing the front, there was no access to the screws that hold the CD Music unit to gain access to the Nav unit.
None the less I removed the three (easy to remove) case top and side panels to access the units the best I could.
Cleaning the CD Music lens was easy.
Cleaning the top of the plastic protector of the Nav unit was easy.
Blindly, based on the photos, I assumed the Nav lens was in the same spot as the music CD so I inserted a Q-top under the plastic cover CD protector and hoped for luck.
Also cleaned the motor fan blade.
Lastly I completely blow out the case of dust with air and reassembled.
(After 12 years in a Vert the unit did need a de-dusting/ cleaning)
At the moment, the Nav is functioning.
Could be intermittent luck or a successful repair.
Well see over time.
In closing, if you can remove the center console you can remove the unit's side casing and give the unit a deep clean to remove dust and dirt. I'd call it an easy repair.
Thanks to all who contributed to this thread.
Kenny94945 is offline   Reply With Quote
The Following User Says Thank You to Kenny94945 For This Useful Post:
extrapilot (07-18-2017)
Old 07-16-2017, 10:24 PM   #24
LV2TOUR
CF Senior Member
LV2TOUR's Avatar
Well see over time.
well done.
The front door can be left open, then undo the connector in the back.
The unit will have no power, and the front door will stay open, and can be operated by hand.
I plan on deep cleaning my 2006 unit over the winter hibernation period, or sooner if either the CD or Nav do not recognize the CD or DVD.
I have used the CD cleaner disc, and air from a can, and that has kept the units operating well over the years.
Since I had the front portion of the spare unit off, long before closely looking for the laser lens, I can't remember what it had for screws to hold the front part CD or Nav units. I see the pics I posted of the parts, some of the parts that do belong to the front portion of the unit assembly. The screws are all in a plastic bag, likely never to be used again, but keepers, just in case I need a small item for any other project.
Hopefully your endeavours will make for a long term fix.
Old 07-17-2017, 11:43 AM   #25
lovinmyls1
CF Senior Member
lovinmyls1's Avatar
I tried the new cleaning disc but didn't help. I don't think any of the cleaning discs rotate because the radio doesn't recognize it.
But here is the good news: If you can get the dvd player out, you can buy a brand new GM Denso player on fleabay for 77.00$. I was amazed when I saw this. I tried to remove mine but the some of the screws were so tight I was stripping them. Also it was unclear to me if the front cover has to come off. I have since found a pdf on how to remove it. The pdf was created by NAV Tool to show how to install their rear camera to show on the nav screen. I would include it but it seems to be too big to include here. I probably could email it if anyone needs it or you may be able to find it on NAV Tools website. Hope this helps. If anyone can successfully remove cd and dvd show us how you did it.
The Following User Says Thank You to lovinmyls1 For This Useful Post:
Old 07-17-2017, 04:37 PM   #26
Kenny94945
CF Senior Member
Kenny94945's Avatar
lovinmyls1.....Yes, please send me that Nav Tools PDF.
There site seems to be redesigned and asks to contact them for the instructions.'
I'll try to send a PM through this forum w/ my email address.
PS...My luck failed...back to the no recognized Nav disk error message this AM.
Kenny
Old 07-17-2017, 05:01 PM   #27
lovinmyls1
CF Senior Member
lovinmyls1's Avatar
Kenny
Ok Kenny, pm me and I'll be happy to send it. I would like to see a member be able to remove dvd without damaging anything because 77 bucks for a new factory oem dvd unit is fantastic
Old 07-18-2017, 11:02 AM   #28
Kenny94945
CF Senior Member
Kenny94945's Avatar
Hi all that are following this thread.
Yes, received the file from Lovin.
Accordingly the instructions show the removal process of the front screen and surround.
So, yes, if attempting this repair open the screen before removing the radio is the answer to my original comment below:
"Unsure if leaving the screen open would be an option during removal and unsure if an open screen allows for the front screen and surround removal."
Old 07-18-2017, 11:34 AM   #29
extrapilot
CF Senior Member
extrapilot's Avatar
I used the same cleaning disc as lovinmyls1 tried for the CD player with no success, so if I'm feeling brave enough, I will be tearing into the NAV unit in the near future.
I've got this thread bookmarked for future reference also, so thanks guy's..
extrapilot is offline   Reply With Quote
Old 07-18-2017, 03:03 PM   #30
lovinmyls1
CF Senior Member
lovinmyls1's Avatar
News update....I think I've solved my problem. To my way of thinking only two reasons would cause an error message, the machine itself or the disc. So I took a close look at my disc (which is always in the machine) and found...... not scratches but sort of swirls. Since this is a copy of the original, I made a couple more copies and what do you know? ....works great! Tried it yesterday and today around town and no errors at all. So before taking your unit apart you might try another disc ( hopefully you kept the original safe).
Old 07-18-2017, 04:15 PM   #31
extrapilot
CF Senior Member
extrapilot's Avatar
I read or heard someplace that copies of cd's do not last like the originals. Not sure how true this could be, hopefully you found a cure.
Old 07-18-2017, 05:01 PM   #32
lovinmyls1
CF Senior Member
lovinmyls1's Avatar
Never heard that but I would gladly sacrifice copies than ruin a original disc.
Old 07-18-2017, 07:40 PM   #33
Dcasole
CF Senior Member
Dcasole's Avatar
See post 17 ... I asked if we were sure it was not the discs ...
That would have been the first thing I checked
Glad it al worked out
Dave
Dcasole is offline   Reply With Quote
Old 07-18-2017, 07:58 PM   #34
lovinmyls1
CF Senior Member
lovinmyls1's Avatar
Yeah your right!
Old 07-18-2017, 08:05 PM   #35
Dcasole
CF Senior Member
Dcasole's Avatar
Yeah your right!
All that matters is you got it working !
Dave
Old 07-18-2017, 10:20 PM   #36
lovinmyls1
CF Senior Member
lovinmyls1's Avatar
Thanks, I hope some of this info helps the others too.
Old 07-22-2017, 03:04 PM   #37
Kenny94945
CF Senior Member
Kenny94945's Avatar
Well round 2....I was able to fully access 100% the Nav laser lens.
Remove compete Radio/ Nav unit from dash.
Yes, windows down, car open, automatic trans into 2nd gear, leave screen open, eject disks, disconnect battery, place blue painters tape over the screen face as a potential scratch protector.
I may be leaving out some steps as my previous posts should be used in tandem with this post.
Yes, the front screen needs to be removed.
Remove the two screws and their barrels on each side of the screen's retract arms.
I inserted a razor blade between the barrel and arm to lift the barrels and they just lifted out easy and noting it appears blue lock tight is used on these two screws.
Arms recess back into unit (and back out of unit on reassembly) with no issues.
However, I was unable to release the lock for the cable (on the screen side to the unit "guts") to fully remove the screen.
I did not wish to force it, yet the directions I had made it look easy with no special guidance, so I failed here.
Yet, with the clearance I had, I was able to access the two front screws of the CD music unit once the screen and the face plate surround were removed from the case and moved a sold inch away from the front of the unit.
Also of note is a "L" shape copper ground bracket on the upper corner of the surround.
Just take care...I had to bend mine during reassembly.
Once the CD music unit/ case is removed (leave cable attached and just flip it over; out of the way) you have full access to the clear plastic protector on top of the Nav .
I could clearly see the Nav laser lens.
An existing hole in the plastic protector allowed full access to the lens.
I also noted that both the Music and Nav lens are on a flexible attachment...in other words the lens are not solid mounted and I would assume bounce around with rough roads.
Further, I am unsure if lens alignment is a trick the pros use to fully repair these units.
I have no advise, ticks nor noticed anything concerning adjusting/ aligning these lens attachments.
Using some isotopic (sp) alcohol on a Q-tip, followed by a second dry Q-tip was my lens cleaning technique.
Lastly reassembly.
So........Nav disk is working.
Yet, as with my first repair attempt, I don't know if this is luck or a successful long term repair.
Thanks for all the feedback with my thread and here's luck to all who may attempt a lens cleaning.
Old 07-22-2017, 04:20 PM   #38
LV2TOUR
CF Senior Member
LV2TOUR's Avatar
Lastly reassembly.
Thanks,
I'll be doing this to my "good" working unit over the winter, just to clean the lens of the CD and DVD players.
Hopefully, your unit will be as good as new.
Keep us posted from month to month please.
Old 07-23-2017, 03:50 AM   #39
Dano523
CF Senior Member
Bank that the problem is not the lens itself since most blown air will get dust off the surface of the lens, but the prisms down under the lens that reflects the laser returning light to the photo electrical cell that is dirty (and maybe even the face of the photo cell dirty as well).
So the short version, you need to pull the top lens off the laser body, and get down in the lens lower channel to clean the dust off the prisms/mirrors and photo cell face instead.
Dano523 is offline   Reply With Quote
Old 07-23-2017, 09:36 AM   #40
Kenny94945
CF Senior Member
Kenny94945's Avatar
Dano always bring an expert level to the discussion.
For me, I think removal of the lens from its carrier is for the experienced only.
If my Radio/ Nav unit was not functioning at all I might experiment.
Getting to the CD music lens carrier is easier than accessing the Nav lens carrier IMO.
Attempting the prism repair, while still being able to drive the car, again to me has risk.
Plus without guidance I personally still had an issue removing the front screen cable.
The Nav unit may also have cables to disconnect to access its lens carrier...not sure.
Based on Dano's comments, I could disassemble a third time and focus compressed air on the lens carriers. Again lens removal for me may not be possible without guidance.
I think at the moment, I have taken this repair attempt as far as my talents will allow. Other than a third disassembly with the focused air to carrier comment, the next step may likely be part replacement.
Thanks again every one.
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Nav Radio Case - Openning it up
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Nav Door Stuck Open Batman 357 C6 Corvette General Discussion 3 10-07-2017 01:53 PM
    Nav swap Jack Forbes C6 Corvette General Discussion 6 07-09-2017 05:12 PM
    PDR disk missing 2vetteEd C7 Z06 Discussion 19 06-26-2017 07:37 AM
    Backup Copies of Navigation DisK bassman50 C6 Corvette General Discussion 1 03-13-2017 09:04 AM
    navagation dvd gwz51 C6 Corvette General Discussion 12 09-09-2016 09:53 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
