What are the best performance upgrages for the LS 3 engine
Blower kit if you are talking about engine mods only
Install it in the lightest car you can find
HC Mechanic (08-05-2017)
Received 2,060 Likes
Welcome to the forum. If you fill out your profile more than just "male", it'll help understand what you have and where you live.
When you ask a question, you need to be more specific about things like what you want to do. Race the drags or road track, long distance road racing, auto-X, car shows, road trips, or just weekend local drives? Maybe even give a idea of your budget too.
With the only info so far, I'd suggest the $2 shroud prop. It's easily the cheapest tenth you'd ever get on a 1/4 mile timeslip.
Atomic LS3 C6 (08-03-2017)
6th Gear
I want to add another 100-200 HP to my 2008 C6 and I want it to remain reliable. I only use it on the street but when I use it I drive it like a sport bike. My Corvette has the Z51, NPP and 3LT option package, is an A6 and currently has 8,300 miles on it. This is my first Corvette. It handles and goes well but just doesn't have enough punch. I've ridden 1000cc sport bikes for the last 14 years and the Corvette is a replacement for my motorcycle as I'm older and don't bend as well as I used to.
I've looked at the E-force superchargers and wondered how long the stock engine would last under forced induction with the stock 10.7 to 1 compression. The addition of another 100 lbs. to the engine compartment is another issue. The cost is around $8,000 plus installation and a high performance fuel pump depending on the blower kit.
I've looked at Jegs and other companies that offer LS3 crate motors and they have LS3 engines that make 525 HP for around $8,000.
Also, I thought that the installation of a cam, valve springs, CAI and long tube headers and a computer tune might get me around another 100 HP for around $4,000 in parts plus labor.
There is also a company in Texas that makes LS3 performance engines for around the same money. Are they worth it?
I've also thought about a complete engine rebuild on my current engine but think that it might be as waste as it only has 8,000 miles on it.
My budget is up to $10,000 but more HP for less $ is always better.
I want to make a wise choice when making the upgrade/upgrades and I'm looking for some solid advise so anything vendor or component specific would be helpful.
A&A blower. Mine did 560rwhp with just the kit. If you have extra cash invest in long tube headers as well. After that would be a smaller pulley, meth injection and a cam swap. That would put you around 700rwhp. Which is about as far as id personally push a stock bottom end. Some have gone past that and lived, while others have not.
6th Gear
6th Gear
What was the approximate cost of your upgrade and who performed the work and how long or how many miles do you have on the upgrade?
I live in the North East corner of Mass. and am looking for someone located in either MA, NH, ME Ct, or NY to do the upgrade.
I've heard good things about Slowhawk in East Bridgewater Ma.
Is anyone familiar with their work?
Frank
Since it's a street car, and you live in a cooler place, your best bang for the buck easily is the Supercharger.
I have about the same money (or more) in my '08 LS3 in NA mods as the cost of an installed supercharger kit and I only gained about 130 rwhp and much of that is up top. For me, since I want a lightweight, non-overheating track car, this was exactly what I wanted.
But for you, Supercharger all the way.
PS. As an ex Liter bike rider myself, no car will ever come close. That's just the reality.
I have a liter bike, raced liter bakes, and my car easily clowns them. So saying no car will ever come close is SOOOOO wrong.
The following 2 users liked this post by Unreal:
Detoxx03 (08-03-2017),
Atomic LS3 C6 (08-16-2017)
Centri kit, headers, meth. Way below 10k and 700+rwhp if you want..
Centri blower best bang for buck.
All of that will then be a good foundation for a blower kit, which you should have money left over for, when you get bored of the seriously enhanced performance that comes from the first round of mods.
And, most importantly, find a good reputable tuner than knows how to tune an A6 trans, i.e. Not one who rapes the MAF tables or disables the MAF because that will destroy your trans real quick, and then you'll have guys on here telling you that you shouldn't mess with those "junk", "sissy" A6 transmissions, and other such BS.
Good luck with it whatever you do, and please do a build thread.
The following 2 users liked this post by CI GS:
Atomic LS3 C6 (08-16-2017),
Couple of ways to skin the cat,
GM offers a LS3 with ASA cam that will put out 525HP. It street drivable, but border line at best with that kind of surging low RPM's before the motor really want to come alive. To build your motor to the same, about the $3K mark.
Stock motor that way it's build, about 650HP is about the most you want to throw at the rods and pistons that your going to be on the power long term from road race lap to lap, and you can get there quickly with a Super charger with Meth kit alone.
A roots type blow (tvs-2300) will give you linear power from idle to redline (more road course drive-able since you are full torque from idle up), while a centrifugal blower comes on about mid RPM range to max rpms instead.
If the intent is to only use the power for short burst and more for drag strip type running, then a centrifugal type blower with meth kit would be the way to go. The reason for this, you only going to be running short term bursts for a few second each time, what the power at higher rpms, they are able to put out a lot more boost without being heat pumps at the higher pressure, and due to this, cranking the power up to over 700 on the stock motor parts for the short burst is not out of line.
Now just a FYI, before you strap a Blower on a stock motor and expect the piston to stay together for long times of heavy boost over at the 650HP+ mark, you have to pull the rings and increase the ring gaps. If you don't do this (leaves the gaps at say .006~.0010", instead of taking them to .020"~.0250"), what is going to happen with the amount of heat your throwing at the pistons rings, the rings are going to go to heat expand to zero gap to bind on the cylinder walls, and it going to end up with the heads of the pistons snapped off.
Note, the same happens when you are trying to spray too much NOS and the piston rings get too hot as well.
Atomic
Horsepower Addicts in DE did my work. The price was less than $4500. I had headers high flow cats cai cam new timing chain and oil pump and tune. Car did 457 rwhp on the dyno with 425 tq. Not sure of mileage but have driven to KY and back since.
Ron
Ron
