Air intake cover on 2007 LS2
I replaced the air filters on my 2007 LS2. The flimsy plastic cover that goes over both air fillers is not fitting tightly and moves around. Can i just leave it off or will that cause a problem?
Received 19,293 Likes
'20-'21-'22-'23-'24
Moving this to C6 Tech.
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I had the same problem with my LS2, intake, clips that attached the cover were brittle and broke, not keeping the cover tight.
I replaced it with Airaid system, there on the forum here, has vender with good price, easy installations, instructions were perfect.
I know what you are going though, my advice replace it, you want filtered air, not dirty air getting into the intake.
That's my two cents.
https://www.airaid.com/default.aspx
As EOM designed installed that cover does not have a firm fit/ securing.
Perhaps some Velcro?
I believe the cover's purpose to is to prevent water entering the air filters when one opens the hood.
I'd write you can leave it off and have no drivability issues.
