Tires for C6
Tires for C6
Looking for good run flat front tires for 2007 C6
P245/40ZR/18 Original are Good Year Eagle F1.
Don't want to spend over $200/ea. High performance not needed.
Any suggestions?
Any suggestions?
Pro Mechanic
Received 3,952 Likes
check Tire Rack or Discount Tire Direct............... both have websites
Your best bet are the Firestone Firehawk Wide Oval RFTs, they are $1,072.90 on Tire Rack.
Received 1,675 Likes
I'd agree with the FireStone FireHawk suggestion.
My suggestion. Up your budget. Tires is not something you should go cheap on. Not that you have to buy the most expensive tire but you should focus more on the performance of said tire vs the cost.
hrt vlv (08-22-2017)
You may be on to something. I looked at the new firehawk 500, the price sounds good , with an improved compound from previous tire. I will be purchasing these soon. My front tires look like someone is hitting the turns to hard Thanks for your input Bill
Cherokee Nation (09-05-2017)
2020 C6 of the Year Finalist - Modified
Tires
There is a member of our club that is selling a used set in excellent condition. His name is John, 509 998 1541. Why no private messages ? Mike. Firestone run flats.
hrt vlv (08-28-2017)
