AEM x series gauge install problem
Old 08-25-2017, 12:24 PM
13BoostedGS
13BoostedGS's Avatar
Default AEM x series gauge install problem
Hey guys,
I recently installed a triple gauge pod with AEM wideband, x series oil/fuel pressure and X series boost gauges. The wideband works perfectly. The boost and pressure gauges both read "SENS". In the manual "SENS" means that the gauge is not reading the sensor output. I tested the voltage going to both sensors (5 volts) and the voltage coming back from both sensors and both are right on per the manual. I've switched the ignition power source to the gauges and it still reads "SENS". Wiring is in excellent condition. I'm completely stumped. Has anyone other than me had this exact problem?
Old 03-17-2018, 12:57 PM
CORPSEGRINDERC5
2nd Gear
CORPSEGRINDERC5's Avatar
Originally Posted by 13BoostedGS
Hey guys,
Hey just curious if you figured out this problem I am having the exact same problem. I installed the Trio of X-series gauges (30-0300,30-0301,30-0306) and same thing AFR works great and neither the boost or fuel pressure does anything except read "SEnS".
Looking for a fix too I am thinking I have bad sensors but just seems odd that I get 2 bad sensors.
Old 03-17-2018, 01:02 PM
13BoostedGS
I wasn’t able to figure it out so I went with autometer needle gauges. Funny thing is the boost/ vacuum gauge only shows boost. My car is haunted.
Old 03-17-2018, 04:27 PM
CORPSEGRINDERC5
2nd Gear
Well Damn... Did you ever replace the sensors or talk to AEM Tech?
Old 03-17-2018, 09:53 PM
13BoostedGS
I replaced the sensors and still same problem. I wound up returning one sensor and exchanging another for a brand new one. I then decided not to use it.
Old 03-19-2018, 05:24 PM
jayyyw
jayyyw's Avatar
Try putting each gauge on its own ground.
Old 03-19-2018, 05:25 PM
13BoostedGS
I did and nothing.
Old 12-03-2018, 11:05 PM
Z0HM6
Z0HM6's Avatar
ever find the problem?
Old 12-03-2018, 11:11 PM
13BoostedGS
nope, had to send them back.
To AEM x series gauge install problem
Quick Reply: AEM x series gauge install problem
