C6 In-door receiver module problem
told that the problem could be that the indoor module needs to be changed. this module piggy backs the signal from each tire sensor and could be faulty.
2006 C6 convertible ,manual 6 speed. Monterey red
I have replaced and relearned these 2 front sensors (GM unites not e-bay or amazon), my both key fob both work, the remote locking system works. taken the battery cables of their post to start a fresh programming with no luck!!!!
2006 C6 convertible 6 speed Monterey red
has anyone any ideas how to correct this issue I would appreciate the help
by the way does anyone know which door this module is located in (driver or passenger side) and what the cost of this module and if you require a dealer to reprogram this after replacement
