Smoke (Oil) on decel
I had some fun this morning with a white C7 (very nice car) by taking off from the traffic light in a high spirited manner. No laws broken - just 0-60 very quick and when we came to the next light I noticed a cloud on blueish smoke coming from the tail. It definitely smelled like burnt oil.
I have headers, catless x-pipe, corsa extreme mufflers, and a catch can.
I have done some searching and have pretty much concluded that I have either bad rings (need to do a compression check), or the valve guides/seals need to be replaced.
It only does this on decel and I am scheduling a cam upgrade with ECS at the end of this month along with the ATI harmonic balancer fix.
Any other suggestions and/or tips while it's at ECS?
Thank you as always!!!
Usually when you are getting blue smoke on decel it is valve seals. And that is because the intake valves opens and the throttle is closed and a relatively high vacuum is created that is trying to pull air, so one path is the intake valve guide and a blown seal will suck the oil and vapors from the engine. Hence the blue smoke. Of all the bad things a smoking engine is, this is the least hard to fix.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
The valve guide seals will be replaced with the cam install anyway, but I think doing a quick leak down/compression test when we get in there to be 100% sure is a good idea. Most of the work to do that is going to be done for the cam install anyway.
Can't wait to get this scheduled and installed
