Need a wiring diagram right fuel tank harness
So the guy doing my cage dropped the tanks and left the right harness connected which pulled 3 of the 5 pins out of the connector to the chassis. Colors don’t match up between the 2 harness so i need some help with the color and pin location of the tank to chassis main connector. And before the com come in, i tried to buy a new harness and the new harness has different color wires and a different plug for the tank pressure harness. And only one part number exist for this harness.
It’s the right tank harness.
Race Car Tech
I don't have any schematics for the connector on any year but the 2005.
Here it is for left and right tank harness connectors.
Hope it helps
Also attached is the fuel pump removal procedure showing one of the connectors.
Hope it helps
Race Car Tech
I condensed a wiring diagram of the fuel system wiring, and according to the schematic, the right tank BLK wire is the low reference which ties into the low reference tan wiring from the ECM.
The BLK/WT wire goes to ground as can be seen from the attached schematic.
Good luck
Race Car Tech
Glad that it was useful
Good luck
Good luck
