Headers hitting lines on driver and passenger side
Old 11-23-2017, 10:43 AM
JVang
JVang's Avatar
Default Headers hitting lines on driver and passenger side
Problem solved. Didn't torque em to spec. Once torqued fully to spec they give a little bit of clearance.
Old 11-23-2017, 11:04 AM
Todds427
Todds427's Avatar
St. Jude Donor '12
I pulled mine as far as I could, then wrapped with header heat wrap. No issues.
Old 11-23-2017, 05:31 PM
subfloor@centurytrans
Supporting Vendor
subfloor@centurytrans's Avatar
2020 Corvette of the Year Finalist (track prepared)
C6 of Year Winner (track prepared) 2019
Originally Posted by JVang
Headers are hitting cooling lines on both driver and passenger sides. I can only pull them away maybe 1/8” (if that). Do you guys think that insulating the lines will be sufficient enough? What are you all doing? Please advise =)
Two options other than wrapping them.
1) You should be able to bend the lines with a large screwdriver or prybar to gain a little more clearance. Just be careful not to put a hard bend in them.
2) Loosen the headers at the block, wedge a large screwdriver in between the lines and headers, retighten the headers and then remove the screwdriver.
I've done both in the past and they work equally well.
Old 11-23-2017, 05:46 PM
JVang
JVang's Avatar
Thank you!!! I’ll try all of the above and see what works best!
Old 11-23-2017, 06:30 PM
Red Devil
Red Devil's Avatar
What brand and size of headers?
Old 11-23-2017, 10:06 PM
debo
debo's Avatar
No issues with my B&B Headers; recommend wrapping to protect the lines. What brand headers are you using?
Old 11-27-2017, 10:51 AM
EviLS7
EviLS7's Avatar
With my 2 inch stainless works headers they give you a transmission cooler line kit to splice into the lines. Then you route them up above the starter for clearance, not sure if any other companies include that for the 2 inch headers.
To Headers hitting lines on driver and passenger side
Quick Reply: Headers hitting lines on driver and passenger side
