2” vs. 1 7/8” Header
Old 12-27-2017, 11:29 PM
HC Mechanic
HC Mechanic's Avatar
Default 2” vs. 1 7/8” Header
I’m curious to see if anyone has a comparison graph on the 1 7/8 vs. 2” American Racing Headers
Old 12-28-2017, 03:28 PM
redbird555
redbird555's Avatar
http://www.camaro5.com/forums/showthread.php?t=63640
here ya go. 2" is always the better choice
The following 3 users liked this post by redbird555:
CI GS (12-28-2017), HC Mechanic (12-28-2017), xBoostx (12-28-2017)
Old 12-28-2017, 04:45 PM
HC Mechanic
Pretty crazy to see that type of response with only 400 or so horsepower.
Old 12-28-2017, 07:12 PM
cbrtrx
cbrtrx's Avatar
One thing to take into consideration is that the 2 inch don't fit as well and hang a little lower, they are pretty close to everything.
Old 12-28-2017, 07:25 PM
redbird555
redbird555's Avatar
Well my 2” arh clear better than my 1-7/8 looks did so I’m going to have to disagree there. Besides 1/8” here or there isn’t going to make any noticeable difference
Old 12-28-2017, 09:19 PM
xBoostx
xBoostx's Avatar
I removed my ARH 1 7/8 and sold them over how hard it is to remove and install them compared to the Kooks which if you loose a handle on them from the top you have to go under the car to pick em up that's also how easy they are to install.
Also worth mention is the ARH leaked from all 4 in both collectors so I had to cut collectors weld/seal and weld them back on not wanting to ship to the NY and keep car two or more weeks on jack stands got zero for it from manufacturer.
The ARH did fit flush not so the Kooks which hang one full inch below.
All in all I prefer to adjust the Kooks.
Old 12-28-2017, 09:27 PM
CMY SIX
CMY SIX's Avatar
LS2's prefer the 1 3/4 so there goes that argument, I wonder why the OP just didn't ask ARH of
r Kooks?
Old 12-28-2017, 10:23 PM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
The brand vs tube size vs tube length vs collector size vs other mods vs the RPM desired vs the wallet, will all be factors in the best choice.
There are lots of ways to get more power, but the combination of parts and tune to match your desired result is the most important consideration.
Since you're in CA, the 2012-13 Z06 manifold, cats, X-pipe, with any decent muffler will get you through the smog check and give about a 12-15 hp boost.
Old 12-29-2017, 09:10 AM
Boomer111
Boomer111's Avatar
True although I saw the low end HP wise. The big lose is in the torque dept. The long tubes really help the torque.
Old 12-29-2017, 09:56 AM
redbird555
redbird555's Avatar
r Kooks?
This has been proven false many times. No ls engine prefers 1-3/4 over a larger size please stop spreading mis information
bitpilot (09-27-2021), ElisTwoCents (12-05-2020), Plaincoupe (01-10-2018)
Old 12-29-2017, 10:21 AM
WideVette
WideVette's Avatar
Not necessarily. From the same post (#20):
"I don't understand how the 1 7/8 is "best all around header" in your opinion if the 2" headers had better average and peak numbers. Could you please explain? Thanks.
A few Reasons, the additional cost does not justify the gains.
They are a Tighter fit.
They are Heavier
Most manufacturers offer a 1 7/8 headers so they are easier to get.
The biggest gains from headers are in the middle of the curve where you drive most and you can't tell the difference between 1 7/8 and 2 inch, on the dyno graph or in the car.
Unless your Racing you won't miss the 5 HP at 6300 RPM, your not there enough to use it on the street.
Hope this Helps"
Old 12-29-2017, 10:27 AM
redbird555
redbird555's Avatar
They are Heavier
Hope this Helps"
So your reasoning that 1-7/8 might be better is that they weigh a couple pounds less, don’t make any more hp midrange, make less hp up top and are 50 bucks cheaper? I’ll leave fitment out because as I stated I’ve had 2” headers fit better than 1-7/8 on more than one occasionUm seriously? Lol
Old 12-29-2017, 10:31 AM
WideVette
WideVette's Avatar
Sorry! My bad! I forgot you have the bigger d!ck so only your opinion matters! Forgive me, Master!
Old 12-29-2017, 10:36 AM
redbird555
redbird555's Avatar
Whoa man I don’t really pay attention to other guys. Cool if you do though. I was just curious on your reasoning bc literally nothing there is an actual argument on why the smaller header is better. When you’re spending 1200 on a set of headers what’s another 50 bucks? 50/5hp is 10 bucks per hp....good luck getting that ratio with any other mod.If you’ve got actual reasoning then I’d like to hear it.
Old 12-29-2017, 10:42 AM
WideVette
WideVette's Avatar
As I said, my bad, your good. Happy New Year!
Old 12-29-2017, 05:43 PM
HOXXOH
HOXXOH's Avatar
Still kinda hard to explain the quickest LS2 and LS3 bolton cars both running 1.75" headers, isn't it?
The following 2 users liked this post by HOXXOH:
Dcasole (12-30-2017), WideVette (12-29-2017)
Old 12-29-2017, 05:56 PM
redbird555
redbird555's Avatar
I mean no not really, if you have a 10s car and add a mod that makes 5 more hp will you see a change? Nope def not, doesn’t change the fact it’s still a better mod though.It’s weird how many people can stare point blank evidence i the face and then ignore it based on their own formed opinions lmao
HC Mechanic (12-30-2017)
To 2” vs. 1 7/8” Header
Old 12-29-2017, 09:13 PM
Dano523
Dano523's Avatar
Received 3,017 Likes on 2,173 Posts
Yep, tube id size plays second fiddle to actual collect design and how well the header is scavenging the tubes in the first place.
Hence we take something like the below collector with its velocity spike, which will create a great bernoulli effect to scavenge the other tubes,
While a collector like this could be a ***** show instead,
Hence it boils down to the bernoulli effect of the headers, so it stems all the way back to collect and how well it going to do its job firstly creating the needed vacuum effect in the other tubes as one tube fires through it too draw the exhaust out of the other tubes, , then how well it will scavenge the volume of the header pipes from there next (at what exhaust speeds/volumes as well).
So if you use the graph listed in the other link, then there is something wrong with the torque curves, since if the tube lengths are all the same for all the header tubes, then the smaller diameter of the tubes should have the exhaust gasses traveling through the collector faster at the lower RPM's, and will create more HP and torque lower in the RPM range instead.
Hence this is the trade off with tube sizes, being the wider more volume of the tubes, the slower your going to have the exhaust flow through the collect to start with, and it will have more power upper end instead. With smaller tube headers of the same length, its the lower rpms that the headers come on line faster, and depending on the tube size if too small, will be paying the price in the upper end isntead.
As for max HP, it just that, being only used for a brief second before you shift, and what matter more, is the entire power you are making through the working power band of the RPMs you going to running instead.
The following 2 users liked this post by Dano523:
HC Mechanic (12-30-2017), HOXXOH (12-29-2017)
Old 12-29-2017, 11:48 PM
HOXXOH
HOXXOH's Avatar
https://youtu.be/NekTRPx68zs
Thanks for that Dano. I think we both know there are several more factors to be considered when choosing exhaust systems than just primary tube size. The only thing that dyno test did, was to show differences by the same manufacturer on a car with no supporting mods. Dynos are only a stationary tuning tool anyway. Timeslips tell a more accurate story of real performance.
Dcasole (12-30-2017), HC Mechanic (12-30-2017)
Old 12-30-2017, 08:42 AM
Dcasole
Dcasole's Avatar
Received 2,241 Likes on 1,634 Posts
Now that was funny ....
Dave
Quick Reply: 2” vs. 1 7/8” Header
