Ground wire location
Old 12-28-2017, 01:02 AM
mad mikes gto
mad mikes gto's Avatar
Default LQ9 swap Ground wire location
I'm sure this is a dumb question, but Anyone swapped a LQ9 into a C6? If so, where are you putting the ground wires on the block. The cast iron doesn't have the bolt holes like the aluminum block.
Thanks for the help.
Old 12-29-2017, 08:28 AM
69 L46 4 Speed
69 L46 4 Speed's Avatar
On the right side you can put a larger end on the ground wire and attach it to one of the starter bolts. You can also ground from the engine mount bolt on the block and ground it to the frame.
Quick Reply: Ground wire location
