When Does TPMS Sense Pressure Change?
St. Jude Donor '10-'11-'12-'13-'14
I need to make sure my TPMS sensors were registered to the car in the correct order. I will change the pressure a few psi in each tire and check the results on the DIC. What does it take to get the sensors to see the new pressure? If the answer is “drive it”, any idea how much driving it takes? Thanks.
2006 vert.
2006 vert.
usually after you start moving 10-15mph.....
drive around the block
2006 vert.
2006 vert.
I deliberately overinflated my tires at a gas station the other day. Warnings appeared on the DIC before I pulled out onto the street.
