Mantic clutch install questions... - Page 5 - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 01-13-2018, 02:31 PM   #81
Detoxx03
CF Senior Member
Detoxx03's Avatar
Everyone I know thats had or has one hates it.
Detoxx03 is offline   Reply With Quote
Old 01-13-2018, 03:44 PM   #82
C U IN REARVEIW
CF Senior Member
C U IN REARVEIW's Avatar
Quote:
So,should I update my 05 master? Ive had zero issues with it
C U IN REARVEIW is offline   Reply With Quote
Old 01-13-2018, 08:39 PM   #83
Detoxx03
CF Senior Member
Detoxx03's Avatar
Yeah that was answered already.
Old 01-14-2018, 12:21 PM   #84
timd38
CF Senior Member
timd38's Avatar
Guess you don't know me.
timd38 is offline   Reply With Quote
Old 01-14-2018, 12:23 PM   #85
timd38
CF Senior Member
timd38's Avatar
Quote:
Originally Posted by GeneSch View Post
A friend put one in. Started leakin after about 3 weeks.
Mine has been in for 6 years, zero issues.
Old 01-14-2018, 11:36 PM   #86
C U IN REARVEIW
CF Senior Member
Quote:
Originally Posted by Unreal View Post
Brake cleaner
My mantics always came with new flywheel bolts. Not sure if that changed. The new ones have thread locker on them already.
I installed new flywheel bolts that came with clutch (with purple sealer on them)....im being told that I neefef to use red loctite on them??
Old 01-15-2018, 09:49 AM   #87
Unreal
CF Senior Member
Unreal's Avatar
Your so close to being blocked. How many damn times do you need to ask the same question? Do you not read, or not read instruction manuals?
Unreal is offline   Reply With Quote
Old 01-15-2018, 12:44 PM   #88
C U IN REARVEIW
CF Senior Member
So why are you so offended?? Dont respond then....im going off advise from people who have done this before....and this is my first time digging into this car this far!!! Im no master mechanic....and learning as I go.....Whats the damn problem???
Old 01-15-2018, 12:46 PM   #89
C U IN REARVEIW
CF Senior Member
It says "use appropriate loctite"...then you state use supplied bolts w/ sealer".....so who's correct??
Old 01-15-2018, 01:33 PM   #90
Tech
CF Senior Member
Tech's Avatar
Quote:
Buy a service manual. If you're using new bolts, which you should have gotten from Mantic, you needn't use any additional thread locker.
Some people reuse flywheel bolts, in which case you need to use new thread locker.
Tech is offline   Reply With Quote
Old 01-15-2018, 02:39 PM   #91
C U IN REARVEIW
CF Senior Member
THANK YOU! I truly appreciate it. I do have a manual and referenced it for torque specs,but mantic directions kinda contradict each other....and I haven't put bellhousing back on yet....so I was just making perfectly certain I didn't make a mistake. This is not something I want to do again....especially on jackstands. Thank you again.
Old 01-15-2018, 04:49 PM   #92
timd38
CF Senior Member
timd38's Avatar
When you start to abuse the clutch, you will have memories of laying on your back installing it and change your driving habits!
Old 01-15-2018, 05:46 PM   #93
C U IN REARVEIW
CF Senior Member
Quote:
I hope so...lol! Thanks for your help as well.
The Following User Says Thank You to C U IN REARVEIW For This Useful Post:
timd38 (01-16-2018)
Old 01-15-2018, 06:52 PM   #94
NJ_phil
CF Senior Member
Support Corvetteforum!
NJ_phil's Avatar
Just do whatever you need and ask as many questions until you feel comfortable. If you're not sure the factory dab of loctite won't hold, add a dab of your own to it.
PS: Welcome to the **** list lol
NJ_phil is offline   Reply With Quote
Old 01-18-2018, 12:00 AM   #95
C U IN REARVEIW
CF Senior Member
Going back together...
Old 01-21-2018, 04:06 PM   #96
Tech
CF Senior Member
Tech's Avatar
Car back together yet?
Old 01-21-2018, 07:32 PM   #97
C U IN REARVEIW
CF Senior Member
No,everything is ready to bolt in.....but I sent my fuel tanks off for a custom fuel system upgrade and haven't got them back yet. Could install drivetrain,but much easier to deal with fuel tanks with it removed. Hopefully this week.....! Also doing a dual wideband setup,dual valvesprings and guides,fuel rails,injectors and smaller pulley.....so I've got plenty of other stuff to do...lol
Old 01-22-2018, 02:05 PM   #98
lazerlemonta
CF Senior Member
lazerlemonta's Avatar
I just installed my 5.5" triple disc Tilton at the end of December with stage 2 dif and 4.10s. My whole clutch set up weighs 16 pounds, people cry about a 40 pound set up yet mustangs come with them from the factory at that weight. OP you will like the response of the car. There is a possibility you will need to turn off your random misfire codes so your traction control wont glow like a Christmas tree.You may also want to bump your idle up to 750 - 800 rpm. mine is at 850 just for ease of engagement.
lazerlemonta is offline   Reply With Quote
Old 01-22-2018, 06:49 PM   #99
C U IN REARVEIW
CF Senior Member
Good to know,thanks
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Mantic clutch install questions...
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    ARP Flywheel bolts with Mantic twin disc 9000 series always faster C5 Forced Induction/Nitrous 6 02-04-2018 10:44 AM
    WTB: Want to buy Clutch! Blackonblacksls C6 Parts for Sale/Wanted 3 12-02-2017 05:05 PM
    Help, mantic torque specs bdickey058 C6 Tech/Performance 1 06-12-2017 09:55 PM
    Flywheel bolts part number bdickey058 C6 Tech/Performance 5 06-11-2017 10:30 PM
    Mantic Twin guide pin bolts WillRace4Food C6 Tech/Performance 4 02-20-2017 07:04 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
