GS Oil Pressure
GS Oil Pressure
So I've read the forum and see it's common to have high oil pressure with the M6 GS due to the dry sump system. When cold, it takes very little to get up around 80 psi and when warm I'm still frequently in the mid 70's under moderate acceleration. When cold, it can peg triple digits if I get in to it ( I don't do it often, but occasionally someone wants to go for a ride and it would be weird to say, "Sure! Let's drive it around for 20 minutes or so first to warm up the oil."
My question is, what is the most prone component to damage as a result of the constant high oil pressure?
All bearing surfaces on the motor until the motor oil has risen to 175* or better regarding initial wear from friction alone; meaning that all the metal bearing areas in the motor have heat expand stabilized to begin with.
As for the higher oil pressure, easy way to start bending push rods.
To be blunt, until the motor oil temp comes up to at least 170*, keep the revs under 4K.
Thanks for the input. It's kind of annoying that the oil pressure meter is pegged out until i've been driving for 15 minutes. GM should have put at least a 100 psi in all the dry sump cars. It idles at 68 psi when cold, the meter only goes to 80!! Even keeping it under 2k shift points it gets mid 70's and just bothers me when it's maxed on the meter.
