First oil change... Loud noises lol
Did first 2500 mile oil change on my 2009 c6 corvette; drained oil like so;
filled with 6 qts, pulled the fuse primed everything with a couple turns, put fuse back in...
I heard the worst engine noise i've ever heard in my life... turned off immediately..
Tried it all over again, same thing... shut off...
One last time before I said fk it probably blew engine... started up, not even a misfire ran fine.
Is this normal? like wth happened. I have no owners manual and followed a youtube tutorial from someone else. Oil level is on the dot.
I've never heard any noise or of pulling a fuse to prime everything. If you want to crank the engine without starting hold the gas pedal to the floor and push start. Not really necessary IMO.
Oh, and owners manual is available online.
Received 4,713 Likes
Like the others posted, what fuse did you pull & why? A oil change is very simple, remove the drain pan bolt, unscrew the oil filter, put the bolt back in, & screw on a new filter & refill engine with the required amount of oil, you should NEVER hear any unusual noises after a oil change, NEVER
Received 2,061 Likes
Go here for an owner's manual. https://www.corvetteactioncenter.com...ers_manual.pdf
Read pages 5-19 through 5-27. Pay attention to the Oil Life Monitor information. You don't need to change oil before the DIC warning that comes on at 4%. Forget the old school mileage intervals. The OLM will compensate for hard driving vs easy use.
Oil change method:
1. Raise car to access drain and filter and keep it level.
2. Remove pan plug to drain oil and remove filter.
3. Clean filter sealing area, assuring the previous filter gasket is gone. Put a light film of new oil on the new filter gasket and install. Torque to 22 # ft.
4. Clean pan plug and install. Torque to 18 # ft.
5. Pour in 5 quarts of 5W-30 oil that meets either the GM4718M or dexos1 specification. The newest spec is dexos1 gen 2 and will be backwards compatible with your car.
6. Start the engine.
7 After the oil reaches 160* or greater, shut off the engine and wait 5 minutes to check the level. You can drive the car to warm the oil quicker.
8. Add oil to reach the upper hole of the 3 holes on the dipstick.
9. Reset the OLM per the instruction on page 5-27.
10. Check the oil level again after the first tank of gas and add as needed.
There is no need or requirement to pull fuses, crank without starting, prime anything, or pre-fill the filter. You have more residual lubrication in the engine than GM used in the initial assembly process.
Most likely what you heard is called hydraulic hammering. You caused it by doing several things. You added 6 quarts which was an overfill, I'm guessing you most likely pre-filled the filter, and attempted to circulate the oil by cranking the engine a couple revolutions before starting. That left several air pockets between the oil pickup tube and the oil galleys. So when you started the engine, the new oil in the pan hit the air pockets, it compressed the air, which in turn pushed the next oil to the next air pocket and so on. When the air pockets reached the end of the oil galleys where the oil is distributed to the individual bearings, lifters, etc. it was forced out in spurts of air then oil then air then oil, etc until all the compressed air was gone.
Oil change method:
I use my real name because i am a real ASE Certified Mechanic (retired)
I fill the oil filter on any car that i want to last. they will knock if you don't.
Navy Blue 210 (03-26-2018)
I never once filled my oil filter with oil before start up & never have had any kind of knock or hammer in over 40 years of oil changes
Pre-filling the filter does nothing to decrease wear. There is more residual oil in the engine at a normal oil change, than GM used for assembly at the very first startup.
i never put any oil into oil filter and never heard any kind of knock. I assume OP either didn't fill the car with oil or filled the oil into washer fluid reservoir and engine is running dry.
Pre-filling the filter introduces an extra air pocket. The oil pump at 1000 RPM will pump enough oil to fill the filter in .9 seconds. If the filter is already full of oil, the air pressure in the line prior to the filter will compress and force the oil out of the filter, which creates a second air pocket ahead of the oil that was in the filter. When that second air pocket passes by the "barbell", leaving the oil to hit the end of the main galley passage before making a 90 degree turn upward, it has a strong possibility to blow past the o-rings on the "barbell" and into the back of the block by the bell housing. The leakage is the cause of an oil smell that occurs after and oil change and takes several hundred miles of driving to dissipate. The same phenomena can occur if the engine is started and increased to a higher rpm in the first couple of seconds without pre-filling the filter.
I never heard such nonsense in my entire life!
The following 2 users liked this post by Matt Gruber:
astaggs (03-19-2018),
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
"Did first 2500 mile oil change on my 2009 c6 corvette; drained oil like so;"
Hold the phone! Let me get this straight. It is 2018, March. You just did THE FIRST 2500 MILE oil change today? On a 2009 Corvette? Meaning, the original oil has been in there since somewhere around 9 YEARS?
OP, is this a joke? Or, is this a totally new, or rebuilt engine? Or is this a new-to-you (you got it used) and this is the first YOU have changed the oil in the used car?
Because if that really is the FIRST oil change in 9 years, yes, I'd expect just about anything. A-N-Y-T-H-I-N-G.
Maybe others saw a prior thread where you said you just got the used car, had pics posted, etc. No help from me. I'm just wondering....
St. Jude Donor '15
"In honor of jpee"
Got it! Thanks, Eric. As I said, I'm no help but was just wondering.
