Being a California resident is there away that I can install Cal legal headers?
I want to install a exhaust header system for my 012 G.S. LS3 Corvette. Does anybody make a carb legal header system for California? I notice that there are some forum members from California with headers installed in their Corvettes how do they get away with it? whats their secret?
No, headers are illegal in CA. CA emissions do not like the idea of moving the cats downstream at all.
Full Z06 or ZR1 exhaust is our best option.
What would a full ZO6 or ZR1 exhaust bring to the table over a base LS3 exhaust?
TIA, Peter
With long tube headers, you get better scavenging due to the longer tubes, so you pick up about 25hp instead.
So since CA does not have CARB# legal headers (short or long tube), by running the OEM z06 manifold, cats, and X pipe, it's very hard for a novice smog guy to pick up that the oem GM Z06 exhaust parts are not correct for the car model, and does not snag you on having none OEM parts on the car for that model during the smog visual check.
After the CA mandatory emissions recall, my car was not happy with the 4 cat system, especially being boosted. So, I swapped the LS3 NPP exhaust with 4 cats to a full Z06 exhaust (2 cats) and retuned.
On the same dyno with same tuner I gained 28 rwhp and 23 ft. lb. torque. The power increase was throughout the entire rpm.
Swapping from a stock LS3 with NPP to Full Z06 exhaust or even keeping the NPP mufflers and a good tune, expect around 22-27 more rwhp and torque.
Just as a side note:
The Z06/ZR1 exhaust manifolds have hydroformed stainless steel tubes within stainless steel jackets. These tubes are mig welded on the inlet and actually float inside the jacket allowing the expansion and contraction through heat cycles which play an important part in longevity. Notice the space between the tubes and collector's mouth. The shape of the tubes are designed to keep restriction to a minimum. GM did their homework.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Mike, I don't know about the HP gain, but isn't the Z06 full system a slightly different, full NPP, too? I mean IIRC the Z was the first one to get the NPP exhaust in '07. I could be wrong. I do know that the diameter is different, 3" for Z, 2.5" for LS2/3.
Edit: Z06 first had "NPP-style" exhaust in model year 2006 (from HOXXOH post below)
In 2007, the Z06 3" "dual mode" exhaust had an "H" pipe with perforated by-pass pipe in the muffler along with non perforated exhaust tips.
In 2008, the LS3 had the NPP 2 1/2" with an "X" pipe and a solid by-pass pipe in the muffler along with perforated exhaust tips.
In 2011, Z06 had an "X" pipe with a solid by-pass pipe in the muffler along with perforated exhaust tips. Basically, GM used the ZR1 exhaust for the Z06. This made for a louder exhaust at WOT.
In 2012, GM added two smaller cats at the mid pipe for a 4 cat system to all corvettes.
AORoads (05-14-2018)
Received 2,060 Likes
Both very similar systems with design changes over the years.
If you don't have NPP mufflers now and add them in as part of the system, then you can tack on about 6more HP for the NPP mufflers as well.
