good pads for z51 brakes
Need to replace the front & rear pads on my car, its a 2012 with z51 upgrade.. drilled/slotted rotors. Bought the car 4+ years ago and not sure exactly whats on there now, im assuming OEM pads.
All street use / spirited daily driving, but i do need good repeated stopping power from 160+ mph for those fun nights. Car is driven in the rain occasionally, but always like a grandma. 500 at the wheels.
mild dust and a little noise is acceptable for better performance. Carbotech 1521, powerstop z26, hawks?
thanks
thanks
Received 2,060 Likes
thanks
thanks
Badmotorf1nger (05-18-2018)
thanks, yeah i know for sure its the z51/j55 brake setup because the PO upgraded them himself and gave me the paperwork
Supporting Vendor
St. Jude Donor '11,'13
Are you doing back to back 160 pulls? Do you have aftermarket cooling ducts? Im assuming car is SC...
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
Carbotech™ AX6™
The AX6™ is specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range of 50°F to 1000°F + (10°C to 537°C+). The advanced compound matrix provides an excellent initial bite, high coefficient of friction at lower temperatures along with very progressive brake modulation and release characteristics. Many drivers use the AX6™ for street driving as well, even though Carbotech™ doesn't recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT recommended as a race compound in most applications.
Yep, if your running 160MPH and coming down hard over and over again repatiable, then your going to create brake temps well above what most standard street pads can handle without burning up.
The Glitch on a race pads, your not going to be the best braking from the pad until the pad and rotor have warmed up to the needed temp instead. So race pad, stop and go traffic, they are going to semi suck on stopping the car when below their intended working temps instead.
As for the OEM J55 HD pad, it's aggressive Semi metallic pad that does have a slighter heat range than the jl9 pad (both are the same shape and sizes), but works well at lower street temps as well.
Truth is, I would pull the pads on the car, and try to figure out if they are the J55 HD pads to start with, or if someone replaced them with a standard JL9 pad instead. Hence since you have already been using the pads for the way you are driving now, will give you an idea of how the pads have been doing, and what is in the play in the car now.
Hell, who knows, and someone may have stuck cheap Duralast street Ceramic pads in the car, which are not heat rated for what your using the car for, and have no were the initial bite, feed back, or working temps of the J55 HD pad isntead.
And yes, there is a difference between the standard JL9, and the J55 HD pad materials, although both are the same shape and sizes instead.
In the first of the C6's, both where semi metallic, but the pad material on the HD pads is more aggressive, and has a higher working temp instead. On later models, the J55 stayed with the aggressive Semi metallic higher heat range pad, while the JL9 pads when to Ceramic pad instead.
If you can't figure out what pads are on the car, then post the numbers off the pads, and photo of the pads.
No worries, but just a heads up, and I chew through OEM J55 HD pads in about 30K of street uses. Really less, since when I road course the car, the tires and pads get pulled and replaced with my R tires and race pads for such events, the HD pad and street go back on afterwards.
Also with the upgraded Z51 kit, do the rotors look like OEM rotors, or are they aftermarket isntead. Hence someone could have done an aftermarket type Z51 brake upgrade, and some of the aftermarket pads that come with the kits are junk as well.
If the pads are oem HD pads,
J55 HD front pads are gm#19152862 ,
and the rear J-55 HD pads are GM#89026853
IN A/C Delco numbers,
ACDelco 171-0946 front
ACDelco 171-0964 rears
What the pads should look like.
And what the rotors should look like,
But your giving up some slightly higher working temp range of the OEM HD pads, for the lower dusting of the 1521's instead.
Simply, neither pad has the temp range to high speed road course work and not burning them up, but the Oem HD pads do have a working temp range high enough to autocross them, while Carbontech suggest the Ax6 pad for autocross isntead.
Note, This never make sense to me, since autocross is a single run of the course from dead stop on cold tires/brakes, and with the AX6 pads not coming up to temp until 150*, means the first few corners of braking is going to be less than ideal instead.
Supporting Vendor
Very close to each other.
This will give you an ideal of the heat range you are running the brakes on the street, and if you need to go with a pad that has a higher working temp to start with.
