What Size 18" Front Tire Are You Running w/your 305/30/19 Rear
As the title says 18x9 and 19x10.5 combination of wheels, what front tire are you running with your 305/30/19 rear?
19 x 10.5 rear with 305/30/19 tire
18 x 9 front with ? (255/35/18 perhaps or another suggestion that you are running)
I know that we "Need" to keep the front to rear ratio within 1.2" or 1.3" difference if memory serves me correctly .
Thanks, Matt
Thanks, Matt
Nobody else has ever mentioned this with this tire set up so maybe just me being weird. But I thought enough to go back to stock sizes. And noticed the difference immediately.
I was on 10 inch and 11 inch width rims though.
This is what I ran but decided I didn't like the new steering feel. Just felt heavy.
I went from stock size runflats to wider non runflats 265/305 and 1/2" wider TSW rims all the way around. The wider combo was actually lighter than the stock rims and runflats.
But I would say that the overall weight decreased or should decrease in my case too -
Thanks,Matt
(1) I do like that the 265/35/18 (25.3" tire height) to 305/30/19 (26.3" tire height) has a 1" differential and is yielding a taller front tire as compared to the 255 below -
(2) Whereas the 255/35/18 (25.0" tire height) to 305/30/19 (26.3" tire height) has a 1.3" differential - but the front tire is shorter in height on this combo -
I am liking the #1 selection of 265 front and 305 rear, especially since it is not interfering with the wheel/speed sensors, due to the taller front tire -
Thanks,Matt
Thanks,Matt
The rims were LG World Challenge rims. Mid priced so nothing exotic weight wise.
Tires were Kumo, both I would avoid again btw.
I just know the combination I did not care for.
And yes I went from RF to non RF so maybe the weight was much different. Never weighed the items.
I always thought it was due to the wider front tire patch.
Mike's LS3 (05-27-2018)
