Rear Axle drain plug removal
I assume you are talking about the diff. Been awhile, but I think I cut off an allen wrench and then used a wrench on that.
If you compress the rear spring it moves out of the way enough to get the plug out.. I raise the rear of the car , then let it down onto a set of ramps., this compresses the rear spring and then you can get to the plug...WW
I jacked up the right rear and put it down on a ramp to look at the plug. It was more covered than both wheels on the ground. So if I put both wheels up on ramps, I should get enough room to get to the plug? I will give that a try tomorrow.
Rather than trying to put a socket on the plug, use a long ball hex extension. Works like a charm. No need to worry about compressing the spring
Kingstonontario (06-06-2018)
Yes, custom cut down hex head should do the job.
Let us know if you succeed.
Compress spring for access certainly won't hurt.
From my memory, as alternative to spring compression, I believe one can loosen the transaxle rubber mount and then with a jock lift the assembly another inch for access.
I posted this in your other thread but will post here as well.
I decided to move the spring out of the way. Wasn't hard, just added some time. Watch the first part of this video.
I posted this in your other thread but will post here as well.It looks like there is an
https://www.youtube.com/watch?v=3tKSCfmhTBU
It looks like there is other drain plug (18mm) just above the 10mm Hex drain plug. Thanks for every ones input, but please let me know if this is a drain plug or not.
Last edited by Kingstonontario; 06-06-2018 at 01:36 PM. Reason: the size of this other bolt
The hex plug is the drain plug. I do not know what the 18mm bolt is.
When I removed my drain plug I had to use an 18" breaker bar and it still was no joke. Those guys are the factory like to play games with us.
I'm not touching that 18mm bolt until I know what's it for. I'm going to try a long ball hex extension with a pipe on the end. But I don't think there is enough clearance to get it in there. The filler plug took a 18" breaker bar to loosen it. I don't want to take off that spring, that's a lot of work.
I didn't think there was enough room to get it by the spring, but it just made it. I put an adjustable 12' wrench on it close as possible to the spring. With a bit of cranking it came loose. Thanks again Racer1735 and all the others that gave their thoughts. I'm very glad I found this form. to all. I'm so glad I didn't have to go to the Dealer.
Racer1735 (06-06-2018)
