So someone hit a road work sign and than went into my lane and I smacked it.
Welp I got my car back, what a freaken difference... I was unhappy with the work, but owner assured me that he has hired someone new and I wont ever have to worry about what happened again. But pics to follow
I think I might know what wrong with your hadlights... the covers are most likely off.. there are covers behind the headlight and they are for replacing the hid bulbs.. when off, dirt and humidity get into them. Do check up on those.
you'll have to detach your inner wheel lines to get your hand on the inside of he fender.
Maybe this will help if you ever decide to look at this.
first remove your retainers from your liner so you can get your hand inside.
then feel around for these right under the headlights. These are the covers for replacing your bulbs.
if your car doesnt have them... then they might have fallen into your headlight housing and you'll have to remove your headlight assembly to find them. (This is exactly what happened to mine... they were not on and laying on the housing where the headlights sit.
I hope his is somewhat any help to fix this problem . If nothing works then your headlights might be cracked or there is condensation going through bad sealant. Whatever it may be, getting new lens installed will for sure fix those headlights
